MHB Radians to Degrees, Minutes, Seconds
The discussion focuses on converting radians to degrees, minutes, and seconds, specifically for the values 0.47623 and 0.25412. The conversion process for 0.47623 is detailed, starting with calculating the degree equivalent using the formula 0.47623 × (180°/π), resulting in approximately 27.29°. This is further broken down into degrees, minutes, and seconds, yielding a final result of approximately 27° 17' 9.49''. Participants express curiosity about potentially easier methods for such conversions, while acknowledging the straightforwardness of the presented manual approach. The conversation highlights the balance between manual calculations and the use of technology for conversions.
mathdad
Reduce the following numbers of radians to degrees, minutes, and seconds.
(a). 0.47623.
(b). 0.25412.
Can someone work out (a) in steps? I can then use it as a guide to solve (b).
Mathematics news on Phys.org
Okay, here is how I would work a):
First, let's get a decimal approximation for the number of degrees, with a good amount of precision:
$$0.47623\cdot\frac{180^{\circ}}{\pi}=\frac{85.7214}{\pi}^{\circ}\approx27.285969077515198^{\circ}$$
Okay, now we think of this as:
$$0.47623\approx27^{\circ}+0.285969077515198^{\circ}\cdot\frac{60'}{1^{\circ}}\approx27^{\circ}+17.15814465091188'$$
Continuing:
$$0.47623\approx27^{\circ}+17' + 0.15814465091188'\cdot\frac{60''}{1'}\approx27^{\circ}+17'+9.4886790547128''$$
Using standard notation and rounding some, we may write:
$$0.47623\approx27^{\circ}17'9.49''$$
Continuing:
There's got to be an easier way to do this, right?
There could be, but that's the most straightforward way I know to do such a conversion by hand (i.e. without using a calculator programmed to do such conversions).
I recall watching a high school teacher on youtube.com using a totally different method.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
