Radiating sphere inside spherical shell - heat transfer
In summary, the problem asks to find the temperature T_e of the outer radius of a spherical shell with inner radius r_i=10\, r_s and thickness s = 10\, {\rm cm}\ll r_i. The sphere at the center of the shell has a temperature T_s=1073\, {\rm K}, an emissivity e=0.90, and is radiating heat via the Stefan-Boltzmann law. The inner surface of the shell has a temperature T_i = 873 \,{\rm K} and is made of asbestos with a heat transfer coefficient k_a = 0.090 J/(s K m). The temperatures of the sphere and inner surface of the shell are kept constant
FranzDiCoccio
342
41
  • A sphere of radius [itex]r_s[/itex] is at the center of a spherical shell of inner radius [itex]r_i=10\, r_s[/itex] and thickness [itex]s = 10\, {\rm cm}\ll r_i[/itex].
  • The sphere has a temperature [itex]T_s=1073\, {\rm K}[/itex] and and an emissivity [itex]e=0.90[/itex].
  • The inner surface of the shell has a temperature [itex]T_i = 873 \,{\rm K}[/itex] and it is made of asbestos . The heat transfer coefficient of asbestos is [itex]k_a = 0.090 J/(s K m)[/itex].
  • The text says that the temperatures of the sphere and of the inner surface of the shell are "kept constant".
  • The problem asks to find the temperature [itex]T_e[/itex] of the outer radius of the spherical shell.
  • Stefan-Boltzmann law (radiated heat power)
[tex]P = \sigma e A T^4[/tex]
  • Heat transfer through a rod (should be ok for the spherical shell on account of its thinness)
[tex]P = k_a \frac{A}{s} \Delta T[/tex]
Of course the problem is solved if one can estimate P in the second equation.
I guess it could be a matter of balance of heat radiated by the sphere and (possibly) by the inner surface of the shell. The sphere radiates heat, and, if the shell is not totally reflecting, it is going to absorb part of it.
If that is the case, it should also radiate some heat back.
I'm not sure of how to take into account that "the temperatures of the sphere and of the inner surface of the shell are kept constant".
The power absorbed by the inner shell could be
[tex]P_i = \sigma e_i A_i (T_s^4-T_i^4)[/tex]
But I'm not sure about at least a couple of things
  1. the S-B law applies to a concave surface. Perhaps it works because the shell radius is "large". Anyway, I do not know [itex]e_i[/itex]. The problem does not give it.
  2. it seems to me that the shell absorbs more energy than the sphere radiates (because of the larger surface).
Another possibility is that the inner shell is considered as the (radiating) "surroundings" of the sphere. So the net power emitted by the sphere is
[tex]P_i = \sigma e_s A_s (T_s^4-T_i^4)[/tex]
and all this power for some reason is trasmitted through the shell.
This does not convince me either.
I think that this problem should be solved using the two equations I wrote (these are the only equations about heat transfer that could be found in the book where I found the problem).
I'm not sure about the interpretation of the problem. But, suppose you are meant to assume that the net amount of radiant energy in the volume between the sphere and the shell remains constant in time. Can you deduce the net rate at which radiant energy is absorbed by the shell? Then, can you get the temperature of the outer surface of the shell assuming that the shell is in a steady state of heat conduction?
Hi TSny
I'm not sure about the interpretation either.
I think that your second question can be rephrased as: can you get the temperature of the outer surface if you know P in the heat transfer equation?
Of course yes. I would know everything but the external temperature, so that would be easy.
I'm not sure about how to answer your first question.
It seems to me that you can determine the net radiant heat transfer to the shell by assuming that the total amount of radiant energy in the space between the sphere and the shell remains constant.
Uhm, I'm not seeing this. The sphere is radiating heat at some rate (S-B law). Possibly the inner shell is also radiating back some energy, at some other rate. Whatever these rates are, wouldn't the radiant energy between the sphere and the shell be time-independent?
Maybe I'm saying a very stupid thing, but I'm very tired now. Here's pretty late, and I have been up for 18 hours now.
I think I'd better go to sleep now. I'll think again about this tomorrow.
Thanks a lot for your help.
Maybe I'm getting a little unstuck on this.
Perhaps I can see it this way
  1. The net power radiated by the sphere is [itex]P_s = \sigma e_s A_s (T_s^4 - T_i^4) [/itex], where the term with [itex]T_i[/itex] accounts for the power radiated back by the shell. I can use this in the lhs of the heat transfer equation, meaning that whatever power is not scattered back goes out
  2. This is not entirely satisfactory, because I'm focusing on the sphere, whereas I need the power through the shell. I'd be happier if I had some equation(s) like the one in 1., but for the shell. I still think that there is something weird, something I cannot put my finger on. The net power radiated by the shell would be something like [itex]P_i = \sigma e_i A_i (T_i^4 - T_s^4) [/itex]. Since the sphere is hotter than the shell, this would be negative. Ok, indeed there is some power going out. But then perhaps it should be [itex]P_i =- \sigma e_s A_s T_i^4[/itex]. I do not know whether this makes sense. Is this supposed to fix the relation between [itex] e_i[/itex] and [itex]e_s[/itex] for equilibrium at those temperature to occur? Also, probably the equation for [itex]P_i[/itex] should contains some additional term to account for the fact that some of the power radiated by the inner shell does not hit the sphere and goes back to another point of the shell.
Can I use the equation in 1 safely? Am I missing something?
Thanks
I might be oversimplifying the problem. I'm considering that we have steady-state conditions. So, the net amount of radiant energy in the space between the sphere and the shell is not changing with time. The net rate at which radiant energy is transferred to this space by the sphere is [itex]P_s = \sigma e_s A_s (T_s^4 - T_i^4) [/itex]. Since the total amount of radiant energy in the space between the sphere and the shell must remain constant for steady-state conditions, you can deduce the net rate at which radiant energy is removed from the space by the shell. In order for the shell not to "heat up", it must conduct a certain amount of heat per second to the outside environment.
If I look at it this way, I seem to get a reasonable answer for Te. The emissivity ea of the asbestos is not needed.
Hi again TSny,
and thanks for your insight. I came to the same conclusion as you, but in a much less clear headed way. I could not wrap my head around this problem because I was kind of obsessing on the spherical shell, which is possibly the worst angle to look at the problem.
I solved the problem according to the above formulas and I got the solution given in the book. So this must be what they had in mind (btw, one of the numbers above is wrong, the shell thickness is 1,0 cm and not 10 cm as I wrote).
Thanks again
OK, good.
Related to Radiating sphere inside spherical shell - heat transfer
1. What is a radiating sphere inside a spherical shell?
A radiating sphere inside a spherical shell is a heat transfer phenomenon in which a sphere is enclosed within a larger hollow sphere. The inner sphere is heated, causing it to emit thermal radiation which transfers heat to the outer shell. This is a common scenario in many engineering and scientific applications.
2. How does heat transfer occur in a radiating sphere inside a spherical shell?
Heat transfer occurs through thermal radiation, which is the transfer of heat energy through electromagnetic waves. The heated inner sphere emits radiation in all directions, and some of it is absorbed by the outer shell, causing it to increase in temperature. This process continues until thermal equilibrium is reached.
3. What factors affect heat transfer in a radiating sphere inside a spherical shell?
The rate of heat transfer in this scenario is influenced by several factors, including the temperature difference between the inner and outer spheres, the emissivity of the inner sphere's surface, the distance between the two spheres, and the material properties of the inner and outer spheres.
4. How can the rate of heat transfer be calculated in a radiating sphere inside a spherical shell?
The rate of heat transfer can be calculated using the Stefan-Boltzmann law, which states that the rate of thermal radiation emitted by a body is directly proportional to its surface area and the fourth power of its absolute temperature. This law can be used to determine the amount of radiation emitted and absorbed by the inner and outer spheres, thus allowing for the calculation of the heat transfer rate.
5. What are some real-world applications of a radiating sphere inside a spherical shell?
This heat transfer phenomenon is commonly observed in many industrial and scientific processes, such as in the design of thermal insulation materials, the study of planetary and atmospheric temperatures, and in the transfer of heat in furnaces and boilers. It is also relevant in the fields of astronomy and astrophysics, as it helps to explain the transfer of heat in celestial bodies such as stars and planets.
12K
13K
