Radiation absorption and temperature changes in matter
In summary, the discussion focused on the mechanisms by which high-energy radioactive decay products are attenuated as they pass through matter. The general consensus is that these particles and rays interact with electrons in the target material, causing ionization and electronic excitation. This results in the production of more particles or photons in the target material, ultimately leading to an increase in temperature. The process involves the excitation of vibrations and rotations in the atomic lattice of solids, which is what we perceive as a temperature increase. Both slow and high-energy particles can cause this heating, but high-energy particles tend to transfer higher energies, requiring additional steps to reach thermal energies.
Alexander83
35
Hi there,
I've been studying mechanisms by which high-energy radioactive decay products (beta particles, x-rays, gamma rays) are attenuated as they pass through matter. From my readings in introductory and intermediate level textbooks, the general mechanisms by which these particles and rays are described as interacting with matter generally involves interactions with electrons in the target material either causing ionization or electronic excitation.
My gut feeling is that the net effect of all of these interactions will (eventually) be an increase in the temperature of the target material. The mechanisms that are commonly described in books for attenuation of radiation such as photoionization or Compton scatter in the case of photons, or Bremsstrahlung production or collisional ionization in the case of energetic electrons. These mechanisms would seem to result in the production of simply more particles (free electrons) or photons in the target material.
My (very) naive understanding of what a change temperature means in a solid structure would be something along the lines of excitation of vibrational or rotational modes in an atomic lattice with the resulting increase in the kinetic energy of the atoms of the substance resulting in what we perceive as an increase in temperature... is this correct?
My question then is this: how do the interactions I mentioned earlier ultimately result in a temperature change in the target? My gut feeling is that secondary radiation produced in a target continuously decreases in energy level until it is at the correct energy level to excite vibrational or rotational modes in the target, causing what we think of at a macroscopic level as "heating" but I can't find anywhere where this is spelled out. Introductory texts seldom go into much detail much beyond discussing the mechanism of the initial attenuation of high energy radiation and not subsequent steps.
Thanks for you time!
Chris.
All charged particles are ionizing (and the slow electrons then collide with atoms and other electrons and heat the material) and/or directly transfer momentum to atoms (-> heat). Neutral particles can hit nuclei, or produce secondary radiation with charged particles.
If heating due to radiation is significant, the radiation levels are really high.
Likes 1 person
mfb, thanks for the post. I think I'm trying to ask about the process that you described as
"the slow electrons then collide with atoms and other electrons and heat the material"
I think I'm struggling to think about what it means to say that the material is heated... is this an excitation of vibration of the atoms in a lattice in solids which is what we conceive of as a temperature increase? If that's the case, why is it that slower moving particles cause this excitation and heating and not higher energy particles?
Chris
Excitation of vibrations of atoms and excitations of electrons.
Both do it, but the high-energy particles tend to transfer high energies to particles they "hit", so it takes some steps to get to thermal energies (~1/40 eV at room temperature).
Likes 1 person
Related to Radiation absorption and temperature changes in matter
1. What is radiation absorption?
Radiation absorption is the process by which matter absorbs electromagnetic radiation, such as heat or light, and converts it into thermal energy.
2. How does radiation absorption affect temperature changes in matter?
When matter absorbs radiation, it gains thermal energy which causes its temperature to increase. The amount of temperature change depends on the type of radiation, the properties of the matter, and the amount of radiation absorbed.
3. What is the difference between conduction and radiation absorption?
Conduction is the transfer of heat between two objects in direct contact, while radiation absorption is the transfer of heat from electromagnetic radiation to matter without direct contact.
4. How does the type of matter affect its ability to absorb radiation?
The ability of matter to absorb radiation depends on its physical properties, such as color, texture, and chemical composition. Different materials have different absorption coefficients, which determine how much radiation they can absorb.
5. Can radiation absorption cause changes in the state of matter?
Yes, radiation absorption can cause phase changes in matter. For example, when ice absorbs radiation, it melts and changes from a solid to a liquid state. Similarly, when water absorbs radiation, it can vaporize and change into a gaseous state.
  • Atomic and Condensed Matter
  • Biology and Medical
  • Quantum Physics
  • Thermodynamics
