A Radiation back reaction in classical electrodynamics
The discussion centers on the unresolved issues surrounding radiation reaction force in classical electrodynamics, particularly for point particles, with no universally accepted breakthrough to address problems like pre-acceleration and runaway solutions. When Maxwell's equations are coupled with dynamical extended bodies, such as charged fluids, the resulting equations do not face the same issues as point sources, and these models are considered physically reasonable. However, the mathematical soundness of classical electrodynamics coupled with fluid dynamics remains uncertain, with doubts about the existence and uniqueness of solutions. Despite these theoretical challenges, fluid models of plasmas have effectively described physical phenomena. The Landau-Lifshitz approximation is noted as a better approach to the radiation-reaction problem than the Lorentz-Abraham-Dirac equation, with suggestions for a quantum-Langevin approach to avoid classical issues.
HomogenousCow
I've been doing some research on the topic of radiation reaction force/self force in classical electrodynamics and although there are some discussions on the internet I would like direct answers to these following questions:
  1. Is there a rigorous and universally accepted treatment of radiation reaction force in classical electrodynamics for point particles? If so what was the breakthrough that solved the issues plaguing the seminal works such as pre-acceleration and runaway solutions?
  2. If we couple Maxwell's equations to a dynamical extended body, such as a charged fluid, do the resulting equations suffer from the typical issues encountered with point sources? And if not, does this treatment predict radiation reaction force that is physically reasonable?
  3. Is classical electrodynamics coupled to fluid dynamics a mathematically sound theory? As in, are there results on the existence and uniqueness of solutions in this theory.
There is no such breakthrough. Those issues remain unresolved.
Extended bodies with charge densities that are everywhere finite are physically reasonable.
I don’t know, but I am not aware of problems like those with classical point particles.
Likes vanhees71 and jasonRF
I don't know if existence and uniqueness has been settled (I really doubt it), but a 30-second google search yielded some interesting hits like
https://www.jstor.org/stable/20209485
http://wrap.warwick.ac.uk/66955/
This is more in the realm of mathematics than physics, in that few physicists probably have the tools (or inclination) to make much progress on that front.
Even if those issues haven't been resolved, fluid models of plasmas have been pretty successful at describing physical phenomena. So have the more accurate kinetic models that can be used to derive fluid models by taking velocity-space moments.
jason
Likes vanhees71 and Dale
According to "numerical studies" the best we have on the classical level concerning the radiation-reaction problem is the Landau-Lifshitz approximation to the Lorentz-Abraham-Dirac equation. For a nice treatment, see
C. Nakhleh, The Lorentz-Dirac and Landau-Lifshitz equations from the perspective of
modern renormalization theory, Am. J. Phys 81, 180 (2013),
https://dx.doi.org/10.1119/1.4773292.
https://arxiv.org/abs/1207.1745
K. Lechner, Classical Electrodynamics, Springer International Publishing AG, Cham
(2018), https://doi.org/10.1007/978-3-319-91809-9
Likes Dale and jasonRF
In his derivation, Lechner states on page 467, "Ultimately the Lorentz Dirac equation must be postulated."
But the LAD equation is not the solution! The Landau-Lifshitz approximation is much better. A quantum-Langevin approach (at least for the non-relativistic case) suggests that the real matter is a non-Markovian description on the classical level, which avoids all the problems of the LAD equation right away. For this, see
G. W. Ford, J. T. Lewis and R. F. O’Connell, Quantum
Langevin equation, Phys. Rev. A 37, 4419 (1988),
https://doi.org/10.1103/PhysRevA.37.4419
or
https://doi.org/10.1016/0375-9601(91)90054-C
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
