Radiation shielding and redirecting
In summary: The water droplet is moving around, but because it's shown in a two dimensional view, it appears that the water droplet is still in the water.
  • #36
phinds said:
And you keep ignoring repeated statements that it will NOT reduce the strain on the actual shielding unless you increase the total mass involved, which makes it not a good idea.
you've tried this have you? isn't that what science is about? testing things before we are absolutely certain of them? we do not know everything about everything. and it is those unknown discoveries that make science so wonderful. because we are still trying to figure out what is out there. we can run test after test. but until you try everything, you cannot be certain. try to keep an open mind. i cannot say it enough, materials science is making new findings all the time.
  • Skeptical
Likes weirdoguy
Astronomy news on Phys.org
  • #37
You aren't talking Science; you are talking ignorance of Engineering and Technology. What possible sort of system are you actually proposing that would be 'better' than lead / concrete or some other dense substance and which would make good use of the small amount of power that is carried by the cosmic rays? What sort of "strain" are you suggesting that the screening material is subjected to?
You are in the land of 'Wouldn't it be nice if', which has a rich supply of Unobtainium. Pretty much nonsense all round, I'm afraid. To follow PF rules you need to cite some evidence to support your ideas. Do you have a single credible reference to this?
Likes phinds, marcusl and Bystander
  • #38
To shield against radiation you need some material that converts the ionizing radiation to several low-energy particles. Once you have done this the radiation is not harmful any more.
To extract energy from radiation you need some material that converts the ionizing radiation to several low-energy particles and some additional material to use these low-energy particles. While this additional material can also do the initial conversion it won't be better in it (otherwise you would use it everywhere). Harvesting the energy cannot improve overall shielding because it is a step that happens downstream. In practice it will get worse because you are more limited in the material choice for some elements.
To make it worse: If you don't plan to extract energy you can just use any bulk material, stopping everything in the material. If you plan to extract energy you need to make sure the particles reach your setup. You are more limited in the material choice here as well and you need a more complex geometry. Your shielding will be worse.
Likes phinds, marcusl and Klystron
  • #39
X-ray optics just happens to be my field and by extension, gamma ray optics. Short answer about redirecting very short wavelength radiation.....Its really hard but not impossible. For most such energies, reflectivities are so low that you effectively just absorb the radiation. You could do it by reflecting at extreme grazing incidence with reflectivity of .999 and use hundreds of reflections, say 200 reflections at .01 degree or 2 degrees deflection. Still.999 to the 200th power is .81 meaning you've absorbed 19% just deflecting 2 degrees. Now try deflecting 180 degrees (around an object) and you get 1.5e-9 meaning you've absorbed all of it.
Likes Nik_2213 and phinds
  • #40
IMHO, DBO's totally called it on the 'shadow angle'. An absorbing or grazing incidence system set out on a long pylon like the ultimate 'selfie stick' some-what shelters you from that one narrow vector.
Which, IIRC, is where those 'classic' inter-planetary rocket designs, their NERVA-ish nuclear engine and hab separated by a v-e-r-y--l-o-n-g trellis spine, got their start. Think '2001' book/movie and the 'Discovery-1'. They were more interested in minimising their neutron shield's mass, but same 'shadow angle' geometry applies...
Now, if you face multiple radiation sources from very predictable directions, I suppose you could have multiple 'selfie-sticks'. Even if you cross-tie those masts for stability, per 'Tall Ships' rigging, it soon gets a bit unwieldy, a tad wibbly. And, surely, there's a break-even point where, instead of multiple minimal shields on flimsy pylons, makes more sense to keep all that mass closer to the hab, mounted such it won't wibble at the least delta-V...
Bad news, you'd probably do better building a near-spherical bunker of asteroidal slag or, if beyond the ice-line, ice. Think 'swimming pool reactor', but inside-out. Extra thickness between you and your reactor, of course, of course. Requisite mass-haul hurts...
IMHO, if you want a 'force field-ish' whatsit that can efficiently 'steer' such high energy photons, it's probably related to the 'confinement system' around your 'Mr. Fusion Home Energy Reactor'. Requiring multiple major theory and tech advances, that's likely to remain hypothetical for a good while...
  • #41
Unfortunatly, the most x-ray and gamma ray reflective materials are high Z and high density materials such as gold or Tungsten, etc. Because the number of reflections to direct a beam around an object is so high, the total absorption is also very high. You are better of using normal lead absorbers.
This is not a foolish question as I was paid in 1986 t do a study of the use of reflective materials to protect US satellites from a "hypothetical" Soviet nuclear pumped x-ray laser emitting a nominal 1 KeV beam with power density of 10E14 s/cm2 at a distance of 1000 Km. It was a $50,000 6 month program.
Here is my study. Assume a reflectivity of 99% meaning it absorbs 1%. This means it absorbs 10E13 watts/Cm2 of 1 KeV radiation in a time of 50 nanoseconds. Answer: No, no material will withstand that power density in 50 nS
I spent th remaining $49,000 becoming an expert on high heat load x-ray mirrors.
Likes sophiecentaur
  • #42
OOOps, should have been 10E14 watts/cm2 incident then 10E12 watts/cm2 is absorbed.
BTW, just out of interest, index of refraction for x and gammas is less than 1 and has a major imaginary part corsponding to absorption.
  • #43
To the degree that the exposure problem comprises mechanical damage impairing the functionality of genetic molecules, seeing that the human genome project is way ahead of schedule, and anticipating nanobots, the long term solution may be biological intervention rather than shielding.
The way forward may be to allow an otherwise lethal count of gamma ray passage through the astronauts; then mitigate the damage incurred to the genetic molecules continuously, repaired by the nanobots propagated, stationed, and operating together within every cell nucleus...?
  • #44
And now we’ve come full circle from one sci-fi fantasy to another.
Likes phinds
  • #45
Agreed. This is a good time to tie off this thread. :smile:
Likes sophiecentaur
