How Efficient Can a Radiative Heat Engine Be for a Moon Base?
In summary, the task at hand is to construct a heat engine using radiation collected from the Sun to power a Moon base. The maximum theoretical efficiency for such an engine can be calculated using Wien's law and the ratio of temperatures between the Sun and the Moon. The result is an efficiency of 0.95. However, the practicality of achieving this efficiency is questionable due to the need for optical systems to focus the Sun's light onto the surface and the limited angle at which the Sun can be seen from the Moon. It may be more realistic to aim for a lower temperature, such as 1000 K, for the heated material.
Physgeek64
247
The emission of radiation from the Sun’s disc is observed to peak at 0.5 μm wave- length and that from the Moon’s disc at 10.0μm. A heat engine to power a Moon base is to be constructed using radiation collected from the Sun. What is the maximum theoretical efficiency of such an engine? Comment on whether it would be practical to achieve this.
##T\lambda_{max}=constant##
##T_{moon}\lambda_{moon max}=T_{sun}\lambda_{sun max}##
##\frac{T_{moon}}{T_{sun}}=0.05##
##\eta=1-\frac{Q_2}{Q_2}##
##\frac{Q_2}{Q_1}=\frac{T_2}{T_1}##
##\eta=1-0.05=0.95##
does this seem right? I feel like assuming the radiation is the same temperature as the sun is wrong
but i don't know how to relate this all together. Any help would be greatly appreciated. Many thanks
I believe you computed it correctly. One item of interest is the constant in the Wien's law formula is ## 2898 \, \mu m \, K ## making the temperature of the (surface of the} sun ## T_{sun} \approx 6000 \, K ## , and that of the moon ## T_{moon} \approx 300 \, K ##. ## \\ ## Note: The question also asks to comment on whether this is practical. To answer this question really requires some additional background material, so let me provide some of that info: ## \\ ## In order for light from the sun to be able to heat an object up to ## T ## anywhere near ## 6000 ## K , you would need to use lenses to focus the light onto the surface, (with the surface in the focal plane of the lens), and the lens system would need to fill a good portion of the hemisphere surrounding the surface being heated. Is this practical? ## \\ ## Without the use of optics, the sun only subtends an angle of ## \Delta \theta=.01 ## radians, (as seen from the Earth or moon), and would basically heat up surfaces that are placed on the moon to the same temperature as the surface of the moon. (That's why the moon is at the temperature that it is. The moon's surface, (assuming emissivity 1.0, but this same dynamic equilibrium also holds for a greybody), is radiating away energy as a blackbody at temperature ## T_{moon} ##, at the same rate that it is receiving energy from the sun). ## \\ ## Additional question: Would it perhaps be somewhat more practical to use lenses to make a heat engine system where (smaller) lenses heated the material to a temperature in the neighborhood of ## T= 1000 \, K ## ?
Related to How Efficient Can a Radiative Heat Engine Be for a Moon Base?
What is a radiative heat engine?
A radiative heat engine is a device that converts heat energy into mechanical work using the principles of thermodynamics and the transfer of heat through radiation.
How does a radiative heat engine work?
A radiative heat engine works by using a hot source, such as a fire or the sun, to transfer heat through radiation to a working fluid. The working fluid expands and pushes against a piston, creating mechanical work.
What are the key components of a radiative heat engine?
The key components of a radiative heat engine include a hot source, a working fluid, a heat exchanger, and a piston or turbine. The heat exchanger is used to transfer heat from the hot source to the working fluid, and the piston or turbine converts the pressure from the expanding fluid into mechanical work.
What are the advantages of using a radiative heat engine?
One of the main advantages of using a radiative heat engine is that it can operate using a wide range of heat sources, including renewable sources like solar energy. It also has the potential to be more efficient than other types of heat engines, as it can take advantage of the high temperatures of some heat sources.
What are some real-world applications of radiative heat engines?
Radiative heat engines have a variety of potential applications, including power generation, space propulsion, and waste heat recovery. They can also be used in industrial processes that require high temperatures, such as steel or glass production.
11K
  • Mechanical Engineering
