Radiative Heat Transfer Problem
In summary, to calculate the rate of radiative heat transfer in kW, you can use Stefan's Law of Radiation which states that E = sigma*A*T^4, where sigma is Stefan's constant, A is the area, and T is the temperature. In this case, with an epsilon value of 0.95 and a sigma value of 5.67 x 10^-11 kW m^-2 K^-4, you can apply the formula to find the rate of radiative heat transfer.
BSFE1990
A room has a surface mean radiant temperature of 20oC. if a heat source of area 2 m2 at 200oC is introduced into the centre of the room, what is the rate of radiative heat transfer in kW?
Can anyone help me with this question? I can't find any examples in my notes or online and need help quick ... Thanks guys
TRY TO APPLY STEFAN'S LAW OF RADIATION.
E=sigma*A*T^4
where sigma is stefan's constant.
A is area.
T is temperature.
Thanks for the quick reply just noticed there was a bit of information missing from the question ... epsilon =0.95, sigma = 5.67 x 10^-11 kW m^-2 K ^-4
So it must be stefan's constant
Related to Radiative Heat Transfer Problem
1. What is radiative heat transfer?
Radiative heat transfer is the process in which heat is transferred through electromagnetic waves, such as infrared radiation. It occurs between objects that are at different temperatures and do not have direct contact with each other.
2. How does radiative heat transfer differ from other forms of heat transfer?
Radiative heat transfer differs from conduction and convection because it does not require a medium or direct contact between objects. It can occur through a vacuum and is primarily dependent on the temperature and surface properties of the objects involved.
3. What factors affect radiative heat transfer?
The factors that affect radiative heat transfer include the temperature and emissivity of the objects involved, the distance between the objects, and the properties of the medium through which the radiation travels (such as air or a vacuum).
4. How is radiative heat transfer used in real-world applications?
Radiative heat transfer is used in many real-world applications, such as in cooking with a microwave, heating with a space heater, and cooling with a refrigerator. It is also important in industries such as solar energy, where radiation from the sun is converted into heat for electricity generation.
5. How is radiative heat transfer calculated?
The calculation of radiative heat transfer involves using the Stefan-Boltzmann law, which relates the radiation emitted by an object to its temperature and surface properties. Other factors, such as the geometry and orientation of the objects, also play a role in the calculation.
