Radiative Transfer + Emissivity
In summary, radiative transfer in a homogeneous gas layer involves both absorption and emission processes. Light can be scattered within the gas, but this is not explicitly accounted for in the equation provided. Emissivity is a measure of how efficiently a material emits radiation, and self-absorption can occur in dense gas. Different temperatures in the gas can lead to a mixture of spectra, but advanced modeling techniques can help to separate them out.
nordmoon
68
This isn't so much of a homework but rather I am trying to understand the physics. The solution to the radiative transfer for a isothermal homogeneous gas of layer consists of one part that describes the absorption and one part that describes the emission.
My questions about this:
1. What happens to the light scattered? Does this count here?
2. What is emissivity - is this emission?
3. Is light absorbed while it passes throu the gas - does the first term account for this?
4. Can you use the eq. below to simulate the spectra in which both absorption and emission takes place? I am asking because the in the books I have seen they assume strong emitting gas and takes the first term = 0 and for strong absorbing gas and says that emissivity = source function = 0. You can account for both of them?
5. What happens if you have different temperatures in the gas? Do you get a mixture of spectra with different temperatures? Is this a troublesome for diagnostics in which temperatures to be determined? Or does the weaker T blend in the the spectra and you only see the spectra of the highest temperature?
6. What is self-absorption?
I (l) = I(0)exp(-kv N l) + Sv(1-exp(-kv N l)
where Sv is the blackbody, kv absorption coefficient, l is optical length of gas column, N is number of atoms/molecules per volume and I(0) is the intensity before it enters the gas cloud.
See above.
Thank you for your questions regarding the radiative transfer in a homogeneous gas layer. I am happy to help clarify these concepts for you.
1. When light passes through a gas, it can be scattered in different directions by the gas molecules. This can contribute to the overall transfer of radiation within the gas layer, but it is not explicitly accounted for in the equation you provided. Scattering can be included in more advanced models of radiative transfer.
2. Emissivity is a measure of how efficiently a material emits radiation compared to a blackbody at the same temperature. It is related to emission, as a higher emissivity means the material is emitting more radiation.
3. Yes, light can be absorbed while passing through a gas. The first term in the equation accounts for this absorption, as it decreases the intensity of the light passing through the gas.
4. The equation you provided can be used to simulate the spectra in which both absorption and emission take place. However, in certain cases, one of these processes may dominate and the other can be neglected.
5. If the gas has different temperatures in different regions, then the spectra will be a mixture of different temperatures. This can make it more challenging to determine the temperatures of the gas, but it is not impossible. Advanced modeling techniques can help to separate out the contributions from different temperatures.
6. Self-absorption occurs when the gas is so dense that the absorbed radiation cannot escape and is re-emitted, leading to a net decrease in the intensity of the radiation. This can be seen in the first term of the equation you provided, where the intensity decreases as the optical length of the gas column increases.
I hope this helps to answer your questions and deepen your understanding of radiative transfer in a homogeneous gas layer. Keep asking questions and exploring the physics!
FAQ: Radiative Transfer + Emissivity
What is radiative transfer?
Radiative transfer is the process by which energy is transferred through electromagnetic radiation. This can occur through various mediums, such as air, water, or vacuum, and is responsible for the transfer of heat and light.
How does emissivity affect radiative transfer?
Emissivity is a measure of how well an object emits or absorbs radiation. Objects with high emissivity will be better at transferring heat through radiation, while objects with low emissivity will be less efficient at radiative transfer.
What factors can affect emissivity?
Emissivity can be influenced by several factors, including the material composition of an object, its surface texture, and its temperature. Rough surfaces tend to have higher emissivity, while smooth surfaces have lower emissivity.
How is radiative transfer used in scientific research?
Radiative transfer is an important concept in many fields of science, including astronomy, meteorology, and climate science. It is often used to model and predict the transfer of energy in various systems, such as the Earth's atmosphere or the interactions between stars and planets.
Can emissivity be manipulated?
Yes, emissivity can be altered by changing the surface properties of an object, such as its texture or composition. This can be useful in applications where controlling the transfer of heat through radiation is important, such as in building materials or thermal insulation.
