Radio Comm Between 2 Points Diff Gravity: True?
In summary, a source that is orbiting close to a singularity of a black hole is transmitting a radio frequency signal that lasts 60 seconds and is repeated infinitely. The signal is being transmitted using the amplitude modulation method (AM Radio). If the original signal was modulated on a 1000 kHz electromagnetic wave, the wave received must be of 10 kHz.
Hongo
A source that is orbiting close to a singularity of a black hole is transmitting a radio frequency signal that lasts 60 seconds and is repeated infinitely. The signal is being transmitted using the amplitude modulation method (AM Radio). Let suppose that each minute passing in the transmitting source location is equivalent to 100 minutes for the receiver, and that the distance between the transmitter and receiver is time invariant. For this situation to be consistent, it must mean that the electromagnetic wave is stretched. Therefore, if the original signal was modulated on a 1000 kHz electromagnetic wave, the wave received must be of 10 kHz. That would be a similar effect as a doppler effect but the shift of the frequency is produced by gravity instead of the velocity. Is this statement true? Would this mean also that the frequency of a source of light will different depending on the curvature of space-time in the location of the source and the observer? My field is Chemistry so I am sorry in advance for my lack of expertise in General Relativity.
I guess you meant to write "orbiting close to the event horizon of a black hole"?
Yes, but it is not good to view it as "stretched waves", because it tends to conjure up images of 'expanding space' between the source and receiver, which can be very confusing. It is simply gravitational (and velocity) time dilation due to speed and gravitational potential differences between the source and receiver.
If you ignore any relative orbital speeds between source and receiver, the frequency ratio is
[tex]\frac{f_r}{f_s}= \frac{\sqrt{1-2GM/r_s c^2}}{\sqrt{1-2GM/r_r c^2}}[/tex]
where the subscripts indicate source and receiver and r are the orbital radii.
Essentially, yes. Though I'd change "orbiting" to "hovering" - unless you have a rapidly spinning black hole like the one Kip Thorne imagined in "Interstellar", you won't get a stable orbit with that sort of time dilation, and keeping the distance / propagation delay to the receiver time invariant is easier, too.
Related to Radio Comm Between 2 Points Diff Gravity: True?
1. What is "Radio Comm Between 2 Points Diff Gravity: True"?
"Radio Comm Between 2 Points Diff Gravity: True" is a scientific concept that refers to the communication between two points in space that have different levels of gravity. This can occur when objects are in orbit or in different regions of the universe with varying levels of gravitational force.
2. How does radio communication work in different levels of gravity?
In general, radio communication relies on electromagnetic waves to transmit information. In different levels of gravity, these waves may behave differently due to the varying strength of the gravitational force. However, advanced technology and techniques have been developed to account for these differences and ensure successful communication.
3. What are the challenges of radio communication between two points with different levels of gravity?
The main challenge of radio communication between two points with different levels of gravity is the distortion or attenuation of electromagnetic waves. Gravity can affect the speed and direction of these waves, making it difficult for them to reach their intended destination. This can result in weaker signals and potential loss of communication.
4. How do scientists overcome the challenges of radio communication in different levels of gravity?
To overcome the challenges of radio communication in different levels of gravity, scientists use advanced technology and techniques such as directional antennas, frequency adjustments, and signal amplification to ensure successful communication. They also conduct extensive research and experiments to better understand the effects of gravity on electromagnetic waves.
5. What are the practical applications of radio communication between two points with different levels of gravity?
Radio communication between two points with different levels of gravity has many practical applications in the fields of space exploration, satellite communication, and astronomy. It allows for communication between spacecraft and ground control, as well as communication between satellites in different orbits. It also helps scientists gather data and study the effects of gravity on electromagnetic waves in different regions of the universe.
9K
