th078
- 1
- TL;DR Summary
- I'm wondering whether it's possible to craft a RF 'shield' for the Pi Zero's wireless antenna, with the goal of "air-gapping" the device
So I'm trying to put together a Pi Zero mini computer to use for security-oriented applications, for example encrypting/decrypting messages, working with encryption keys, etc. It's cheap, very small and thus easy to carry around.
However, I'm not entirely comfortable with the presence of the built-in Wifi and Bluetooth, which while convenient, presents a security risk. Disabling wireless functionalities via software is possible but not bulletproof, since an adversary could in theory enable them surreptitiously, however improbable that is in practice. I also don't want to physically remove or disable the corresponding components, since that kind of modification is permanent. So I figured that the most straightforward method of air-gapping the device would be to physically shield it the wireless antenna using a RF-blocking material.
Now I have to confess that I know practically nothing about electrical engineering, which is why I've come here for help, in the hopes that someone more knowledgeable might be able to enlighten me and offer some input. I'm aware of Faraday cages and RF blocking wallets, but those require that the entire device be enclosed, which isn't feasible in this case due to the presence of cables.
So instead I was wondering whether it's possible to craft a slip-on RF-blocking "sleeve" using suitable materials and enclose only the antenna. Even if the triangular antenna is completely covered, the silicon board itself wouldn't be enclosed, and might therefore allow signals to pass through. Would that prevent this solution from working?
Thanks in advance.
Thanks in advance.
