Radioactive decay, macroscopic objects
In summary, quantum mechanics allows for the entanglement of a quantum particle and a macroscopic object, as seen in the Schrödinger's cat experiment. This is due to the uncertainty of the nucleus position and can also be observed in the environment of atoms in ordinary objects. However, creating and verifying such entangled systems requires significant effort and is still an area of ongoing research.
durant35
292
Radioactive decay is known to be a pure quantum effect, the particle from the nucleus is in a superposition until we measure it (according to collapse interpretations). In the Sch. cat experiment the radioactive particle gets entangled with a macroscopic object (Geiger counter) and so the macroscopic object is also in a superposition before the decoherence and collapse. Now my question is, by which mechanism something so small effects something so big like an ordinary object and how does a similar effect happen in the environment of atoms in ordinary objects? It seems like nearby macroscopic objects very often enter the superposition state "affected by radiation/not affected by radiation" because of the uncertainty of the nucleus position, just like a measuring device for radiation experiences similar behavior. Is this true and how is it possible?
Thanks in advance.
The Cat experiment is not real. It is imaginary. It is just used for discussion purposes.
It is possible to entangled a quantum particle with a small macroscopic system, true enough. But such system could not be called ordinary in any sense of the word. Such are highly controlled and isolated systems, and it takes a lot of effort to create it and verify it. See below.
http://arxiv.org/abs/1510.02665
"Quantum mechanics predicts microscopic phenomena with undeniable success. Nevertheless, current theoretical and experimental efforts still do not yield conclusive evidence that there is, or not, a fundamental limitation on the possibility to observe quantum phenomena at the macroscopic scale. This question prompted several experimental efforts producing quantum superpositions of large quantum states in light or matter. Here we report on the observation of entanglement between a single photon and an atomic ensemble. The certified entanglement stems from a light-matter micro-macro entangled state that involves the superposition of two macroscopically distinguishable solid-state components composed of several tens of atomic excitations. Our approach leverages from quantum memory techniques and could be used in other systems to expand the size of quantum superpositions in matter."
Likes dlgoff
Related to Radioactive decay, macroscopic objects
1. What is radioactive decay?
Radioactive decay is the process by which an unstable atomic nucleus loses energy by emitting radiation, such as alpha, beta, or gamma particles, and transforms into a more stable nucleus.
2. How does radioactive decay occur in macroscopic objects?
Radioactive decay in macroscopic objects occurs when the atoms within the object have unstable nuclei that undergo the process of decay. This can happen in objects such as nuclear waste, which contains large amounts of radioactive isotopes.
3. What factors can affect the rate of radioactive decay in macroscopic objects?
The rate of radioactive decay in macroscopic objects can be affected by several factors, such as the type of radioactive material, its half-life, and external influences like temperature and pressure.
4. Is radioactive decay harmful to humans?
Radioactive decay can be harmful to humans if they are exposed to high levels of radiation for extended periods. However, low levels of radiation are present in our daily lives and can be beneficial, such as in medical imaging.
5. Can radioactive decay be stopped or reversed?
No, radioactive decay cannot be stopped or reversed. Once an atom has undergone radioactive decay, it cannot be undone. However, the rate of decay can be slowed down or controlled through various methods, such as shielding or radioactive waste management.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
