Radioactive Decay to a Non-radioactive Isotope
In summary, the conversation reveals that Magnesium has multiple isotopes, with only Mg-24, Mg-25, and Mg-26 being non-radioactive. The goal is to convert the unstable isotopes (Mg-20, Mg-21, Mg-22, and Mg-23) into stable isotopes quickly. The options for radioactive decay are electron emission, alpha particle emission, gamma emission, and positron emission. However, none of these options directly add neutrons, which is necessary to lower the atomic number. Therefore, the best option would be alpha particle emission, as it results in a lower atomic mass and can help to stabilize the nucleus.
Teemo
44
Magnesium (Z = 12) has isotopes that range from Mg–20
to Mg–31. Only Mg–24, Mg–25, and Mg–26 are not
radioactive. What mode of radioactive decay would
convert Mg–20, Mg–21, Mg–22, and Mg–23 into stable
isotopes most quickly?
(A) electron emission
(B) alpha particle emission
(C) gamma emission
(D) positron emission
N/A
I assume they want you to convert the unstable isotopes to the non-radioactive isotopes (because they tell you the non-radioactive isotopes), so the goal is to add neutrons. I fail to see any emission which adds neutrons only. A results in higher atomic mass, B results in lower atomic mass, C does nothing, and D results in lower atomic mass.
Red herring. They're just telling you what isotopes of Mg are stable. You've also been told in class that mass number of a stable nucleus is usually at least twice the atomic number, in the case of Mg, 2 x 12 is 24, so the light isotopes are going to fall apart.
So, you've got to get rid of excess protons (positive charge) in the nucleus to get to a lower atomic number. Help?
Sorry for the extremely late reply. But thanks, that makes so much more sense!
Related to Radioactive Decay to a Non-radioactive Isotope
1. How does radioactive decay occur?
Radioactive decay occurs when an unstable atom's nucleus releases energy in the form of radiation to become more stable. This process can result in the transformation of the atom into a different element.
2. What is the half-life of a radioactive isotope?
The half-life of a radioactive isotope is the amount of time it takes for half of the original amount of the isotope to decay into a non-radioactive isotope. This time period can range from fractions of a second to billions of years, depending on the specific isotope.
3. Can radioactive decay be accelerated or slowed down?
No, the rate of radioactive decay is constant and cannot be altered by external factors such as temperature or pressure.
4. What are the dangers of radioactive decay?
Exposure to high levels of radiation from radioactive decay can be harmful to living organisms, causing damage to cells and DNA. This can result in health problems such as cancer.
5. How is radioactive decay used in science and technology?
Radioactive decay is used in a variety of ways, including carbon dating to determine the age of fossils and artifacts, medical imaging, and energy production in nuclear power plants. It is also used in scientific research to study the properties of atoms and their behavior.
  • Nuclear Engineering
  • Chemistry
