MHB Radioactive Substance Decay: ~14g Left After 3 Years
The discussion focuses on calculating the remaining amount of a radioactive substance after three years, starting from an initial 40 grams. The initial decay formula used is N(t) = N0e^(-kt), leading to the determination of the decay constant k as approximately 0.3466. Using this value, the calculation for N(3) yields about 14 grams remaining. An alternative method using the half-life formula N(t) = N(0) × 2^(-t/t1/2) also confirms that approximately 14 grams remain after three years. Both methods agree on the result, validating the calculations presented.
karush
MHB
If 40 grams of radioactive substance decomposes to 20 grams in 2 years, then to the nearest gram the amount left after 3 years is
well i used the $N(t)=N_{0}e^{-kt}$
So $20=40e^{-k2}$ thus deriving k=.3466
Thus $N(3) = 40e^{-.3466(3)}$ resulting in: $N(3)= 14.1410$ or approx $14g$
just seeing if this correct...thnx much(Cool)
Mathematics news on Phys.org
I agree with your method and solution.
As you are given a half-life of 2 years it makes more sense to express the decay by:
\[N(t)=N(0)\times 2^{-{t}/{t_{1/2}}}\]
where \(t_{1/2}\) is the half-life.
So for this problem:
\[N(3)=40 \times 2^{-3/2}\approx 14.1421\ {\rm{gram}}\]
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
