Radiofrequncy Photon Wavefunction
In summary, the conversation discusses the nature of radio waves and whether they can be considered as streams of photons according to quantum mechanics. The possibility of finding a photon in space is described by the dipole pattern, and this can be calculated rather than assumed. The differences between classical and nonclassical states of light are also mentioned, with the understanding that most things that work for classical electromagnetism also apply to nonclassical light.
Frank Peters
28
Radio waves are usually not viewed as streams of photons but according to quantum mechanics that is exactly what they are. But what does the wavefunction of an RF photon look like?
If we consider a dipole radiator, say of 10 Mhz, that emits a single photon, my guess is that the wavefunction of this photon would be identical to the classical dipole antenna pattern. The probablility of finding this photon in space would be described by this dipole pattern. However, once the photon was detected the wavefunction would collapse and the (very small) total energy would be located at that point.
Is this a correct assumption?
Also, if we a consider a directed antenna, such as a yagi, which is only a dipole with passive reflectors and
directors, that emits a single photon, would the wavefunction be "directed" as well? I would guess that it would not be "directed" because a yagi functions by interference and a single photon would not generate interference. But it is a very weak guess because the double-slit experiment shows that a single photon does interfere with itself.
Would there be a "directed" wavefunction with a yagi?
Likes Humaira Khalil
Microwave cavity quantum electrodynamics is done using superconducting qubits. Here is a review (many others are available).
As far as I know, there is no real difference between optical and microwave non-classical states of light (apart from lower energies of course). More to the point of your question. What you do usually, is define the state of your electromagnetic field and then work with operators, such as operators of electric field, to extract experimentally observable quantities, e.g. power. A general rule of thumb, to the best of my knowledge, is that most of the things that work for classical electromagnetism, will also work for nonclassical light, but with much harder formalism. Where you do start seeing differences is in the second and higher-order coherence properties of light.
Likes jfizzix
You would have state of your electromagnetic field ##|\psi \rangle## and the operators of your electric (##\hat{\vec{E}}##) and magnetic (##\hat{\vec{H}}##) fields, and the expectation value of this ##\langle\psi |\hat{\vec{r}}.\left(\hat{\vec{E}}(\vec{r}, t)\times\hat{\vec{H}}(\vec{r}, t) \right)|\psi\rangle## would follow the dipole pattern.
This can all be calculated. No need to assume here.
Likes vanhees71 and Mentz114
Also let me just add that radiowaves are not "streams of photons" but rather coherent states of the quantized electromagnetic field.
Likes vortextor
Related to Radiofrequncy Photon Wavefunction
1. What is a radiofrequency photon wavefunction?
A radiofrequency photon wavefunction is a mathematical representation of a radiofrequency electromagnetic wave. It describes the probability of finding a radiofrequency photon at a particular point in space and time.
2. How is a radiofrequency photon wavefunction different from a regular photon wavefunction?
A radiofrequency photon wavefunction is specifically for radiofrequency photons, which have a much lower energy and longer wavelength compared to regular photons. This affects the shape and behavior of the wavefunction.
3. What are some applications of radiofrequency photon wavefunctions?
Radiofrequency photon wavefunctions are used in various technologies such as radio and television broadcasting, wireless communication, and medical imaging. They are also studied in quantum mechanics to better understand the behavior of electromagnetic waves.
4. Can a radiofrequency photon wavefunction be observed?
No, a radiofrequency photon wavefunction cannot be observed directly. It is a mathematical concept used to describe the behavior of radiofrequency photons.
5. How do radiofrequency photon wavefunctions relate to the electromagnetic spectrum?
Radiofrequency photon wavefunctions represent a small portion of the electromagnetic spectrum, specifically the lower end of the frequency range. Other types of electromagnetic waves, such as visible light and X-rays, have their own corresponding wavefunctions.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
