Radius of a lead nucleus and alpha particle
In summary, the lead nucleus has a radius of approximately 5.91 * 10^-15 m, while the alpha particle has a radius of approximately 1.59 * 10^-15 m. To make contact with the lead nucleus, the alpha particles must have enough kinetic energy to overcome the repulsive force between protons, which can be calculated using equations for electrical potential energy.
Oribe Yasuna
43
A lead nucleus contains 207 nucleons (82 protons and 125 neutrons) packed tightly against each other. A single nucleon (proton or neutron) has a radius of about 1 ✕ 10^−15 m.
(a) Calculate the approximate radius of the lead nucleus.
(b) Calculate the approximate radius of the alpha particle, which consists of 4 nucleons, 2 protons and 2 neutrons.
(c) What kinetic energy must alpha particles have in order to make contact with a lead nucleus?
v_sphere = 4/3 pi r^3
r_nucleon = 1 * 10 ^ -15 m
207 * 1 * 10 ^ -15 m
2.07 * 10 ^ -13 m
Beyond this, I don't have any idea what to do.
I considered using d = m/v, but stopped halfway because I was approaching a bizarre answer.
That would be the approximate length of a chain of 207 nucleons, spaced one radius apart each. That's not how a lead nucleus looks like. Where does that multiplication come from?
What are d, m and v?
Did you try conservation of energy?
I figured the radius of a single proton/neutron is 1* 10 ^ -15 so the radius of the nucleus, which consists of 207 protons and neutrons, would be 207 multiplied by 1 * 10 ^ -15 m.
Since 207 doesn't have any units, dimensional analysis checked at least.
Density, mass and volume.
I thought of doing that because I could calculate the mass and volume, but of course density doesn't seem to have anything to do with the problem.
I didn't try the Law of Conservation of Energy (m_1 v_1 = m_2 v_2).
But I don't get how it would help? Doesn't it need at least 1 velocity vector? I only have volume, radius, and potentially mass.
Sorry for the late reply.
If I arrange 27 identical cubes of side 1cm into one large cube, how long is each side of the large cube?
3cm.
Oribe Yasuna said:
3cm.
Right. Not 27cm. So why would a cluster of 207 spheres each of radius 1* 10 ^ -15m have a radius of 207 times that?
So if the number (the volume) increases by a factor of 3, the 'length' increases by a factor of 3.
Now a bulging stuffed bag with 207 oranges. what's the approximate raduis in units of one orange radius ?
[edit] ah, Haru is back. Sorry for barging in ! Bedtime :sleep:.
They wouldn't.
So I took the cubed root of 207 (5.9154817) and multiplied it by 1*10^-15 m.
The answer I got was 5.915*10^-15 m and it was correct.
For part b)
I figured a cube of 4 smaller cubes would have sides of size 2. So I multiplied 5.9154817*10^-15 m by 2 to get 1.18*10^-14 m.
But the answer was wrong. Why? Is it just because I didn't put a fourth significant figure, maybe?
Oribe Yasuna said:
They wouldn't.
For part b)
I don't know why I multiplied by 2.
4^1/3 * 1*10^-15 m = 1.59*10^-15 m
which was the answer for part b).
I don't understand how to get part c).
This is what I know:
r_lead = 5.91*10^-15 m
r_alpha = 1.59*10^-15 m
v = 4/3 pi r^3
K = 1/2 mv^2
1.6*10^-19 J = 1 eV
1 eV = 1*10^-6 MeV
m_proton = 1.6726219*10^-27
m_neutron = 1.6749*10^-24
I calculated v_sphere for the lead nucleus and alpha particle:
v_lead = 8.670795724*10^-43 m^3
v_alpha = 1.675516082*10^-44 m^3
I don't know where to go with this though.
v = 4/3 pi r^3
K = 1/2 mv^2
1.6*10^-19 J = 1 eV
1 eV = 1*10^-6 MeV
Think about this: what makes it hard for the alpha particle to hit the nucleus?
Its size?
Oribe Yasuna said:
Its size?
I suppose that is one problem. But why should any particular energy be required? Why couldn't they just drift slowly together?
Because protons repel each other and they're both made of protons, right?
Right. So how does that lead to a specific energy requirement?
You need enough kinetic energy to move against that repellent force.
So kinetic energy would be equal to the force that the protons repel each other with.
Would that be electrical potential energy?
Yes. Do you know any equations for that?
U = 1/(4 pi E_knot) * (q_1 q_2) / r
1/ 4 pi E_knot = 9 * 10^9 Nm^2 / c^2
r = 5.92*10^-15 + 1.58*10^-15 = 7.50*10^-15
I don't know what q_1 and q_2 are though? Something to do with v_sphere?
They're the charges. Look up the charge of a proton and count the protons in each.
q_1 = 82 * 1.6*10^-19 = 1.312*10^-17
q_2 = 2 * 1.6*10^-19 = 3.2*10^-19
U = 9*10^9 * (1.312*10^-17 * 3.2*10^-19) / 7.50*10^-15
U = 9*10^9 * 4.1984*10^-36 / 7.50*10^-15
U = 5.036144273*10^-12 J
1 eV = 1.6*10^-19 J
5.036144273*10^-12 / 1.6*10^-19 = 3.147590171*10^7 eV
1 MeV = 1*10^6 eV
3.14*10^7 / 1*10^6 = 31.48 MeV
It was correct!
Thanks a ton, I appreciate it.
1 eV = 1.6*10^-19 J
1 MeV = 1*10^6 eV
It was correct!
You are welcome.
Likes BvU
Related to Radius of a lead nucleus and alpha particle
What is the radius of a lead nucleus?
The radius of a lead nucleus is approximately 7.1 x 10^-15 meters.
What is the radius of an alpha particle?
The radius of an alpha particle is approximately 1.2 x 10^-15 meters.
How is the radius of a lead nucleus and an alpha particle related?
The radius of a lead nucleus is larger than the radius of an alpha particle.
What is the unit of measurement for the radius of a lead nucleus and an alpha particle?
The unit of measurement for the radius of a lead nucleus and an alpha particle is meters (m).
Why is the radius of a lead nucleus and an alpha particle important in nuclear physics?
The radius of a lead nucleus and an alpha particle are important in nuclear physics because they help determine the structure and stability of atoms, and can also provide information about nuclear forces and interactions.
14K
