Radius of a planet with the same density as Neptune
I'm afraid you are doing the same mistake again. The mass is ##5.97 \times 10^{24}## kg, not ##5.97 \times 10^{24}## g. It is all right, it is a little confusing, but... you must use mass in kilograms to calculate the volume. So the 1.8657 x 1028 grams is not correct, you must use kilograms, so it is 1.8657 x 1025 kilograms.I think you must do the exercise again. I'm afraid you are doing the same mistake again. The mass is ##5.97 \times 10^{24}## kg, not ##5.97 \times 10^{24}
PhyiscsisNeat
"In January 2006, astronomers reported the discovery of a planet comparable in size to the Earth orbiting another star and having a mass of about 5.5 times the Earth's mass (5.97 x 10^24 kg). It is believed to consist of a mixture of rock and ice, similar to Neptune. If this planet has the same density as Neptune (1.76g/cm^3), what is the radius expressed a) in kilometers, b) in miles"
What I know is that the mass is ~5.97 x 10^24(5.5) = 3.2835 x 10^26 and I tried to convet to grams and got 3.2835 x 10^29 grams. Density is 1.76 g/cm^3[/B]
The question didn't provide equations so I resorted to google. I know that density = mass/volume and I found the equation for the volume of a sphere to be V = 4/3pir[/B]
I started by multiplying the mass of the Earth by 5.5 and got 3.2835 x 10^26 kg, I then converted to grams for division to be compatible with the density of Neptune. So in grams I believe it is 3.2835 x 10^29.
Rearranging d=m/v I get v=m/d. I divide 3.2835 x 10^29 g by 1.76 g/cm^3 and get 1.865625 x 10^29 g/cm^3.
I then take this value for volume and plug it into V=4/3pir.
1.865625 x 10^29 = 4/3pir (this is the same as V = 4pir/3 ??)
I multiply both sides by 3 to remove the denominator of 3 and get 5.596875 x 10^29 = 4pir
I divide both sides by 4pi to isolate r and I get 4.453851611 x 10^28 = r
I apply a cube root to the radius to get 1.645 x 10^29 cm
This is where I get confused. The radius I am getting is no where near the radius of Neptune, despite having the same density? 1.645 x 10^29 cm is an absurd number, so I consulted with wolfram alpha and got a more reasonable number of 3.544 x 10^9.
My calculator says that the cube root of 4.453 x 10^28 is 1.645 x 10^29. Wolfram alpha says that it is 3.544 x 10^9.
Just because the planet has the same density as Neptune, does that mean the radius should be in the same ballpark? My current answer for the radius in km is 35,440,000.
I think I am comfortable enough with algebra to more terms around in these equations to get what I want, but the numbers involved are screwing me up? It's very possible that I made mistakes converting as well. Not sure what the deal is with the differences in cube roots from my calculator vs wolfram alpha.
Any help is GREATLY appreciated.[/B]
Current answer in kilometers is 3,544,000 km.
PhyiscsisNeat said:
V = 4/3pir
##\frac 43\pi r^3##
Try that again.
Check this again.
The formula reads ##V = \frac{4}{3}\pi r^3##
EDIT: I say the same things with haruspex, we just did the post almost at the same time and had no time to see it.
Okay, I multiplied 5.97 x 1024 by 5.5 and I'm still getting 3.2835 x 1026 :(
Edit: Thank you for the correct formula.
It is ##32.835 \times 10^{24}##. Now, do you see the mistake?
Yes, I think so. The order of magnitude stays the same (the same as the Earth) and I'm just multiplying 5.97 by 5.5 to get 32.835. Perhaps I should read the instructions for the calculator. If you're multiplying something that is expressed in scientific notation by another number, is it proper to multiply the two numbers first and then add the 10n after? Because multiplying 5.97 x 1024 in my calculator by 5.5 is giving me 1026.
PhyiscsisNeat said:
Yes, I think so. The order of magnitude stays the same (the same as the Earth) and I'm just multiplying 5.97 by 5.5 to get 32.835. Perhaps I should read the instructions for the calculator. If you're multiplying something that is expressed in scientific notation by another number, is it proper to multiply the two numbers first and then add the 10n after? Because multiplying 5.97 x 1024 in my calculator by 5.5 is giving my 1026.
Yes, you can multiply ##5.97## by ##5.5## first and then just write "times" the power of ##10## you have. Then, if you want to write it as ##3.2835## you must increase the exponent of the power of ##10## accordingly.
What would multiplying 5.97 x 1024 by 10 give? Should multiplying by 5.5 instead give more or less?
Okay, I am back and happy to report that I was having some calculator technical difficulties. Here is my current attempt. Thank you for the responses so far.
First I multiply 5.97 x 1024 kg by 5.5 to get 3.2835 x 1025 kg. I multiply 3.2835 x 1025 by 1000 to get 3.2835 x 1028 grams.
Now that I have the mass in grams, I rearrange d=m/v to get v=m/d and plug the mass and density into get a volume of 1.8657 x 1028.
I set v = 1.8657 x 1028 into the equation V=4/3pir3 and multiply both sides by 3 to remove the denominator and I get...
5.5971 x 1028/4pi = r3. I now have 4.454 x 1027 = r3.
I apply a cube root to get r = 1.645 x 109 cm and I divide that by 1000 to convert to km and I am left with a radius of 1,645,000 km.
Did I screw anything up?
First I multiply ##5.97 \times 10^{24}## kg by 5.5 to get ##3.2835 \times 10^{25}## kg. I multiply ##3.2835 \times 10^{25}## by 1000 to get ##3.2835 \times 10^{28}## grams.
Now that I have the mass in grams, I rearrange d=m/v to get v=m/d and plug the mass and density into get a volume of ##1.8657 \times 10^{28}##.
I set v = ##1.8657 \times 10^{28}## into the equation ##V = \frac{4}{3}\pi r^3## and multiply both sides by 3 to remove the denominator and I get...
##\frac{5.5971 \times 10^28}{4pi} = r^3##. I now have ##4.454 \times 10^{27} = r^3##.
I apply a cube root to get ##r = 1.645 \times 10^9## cm and I divide that by 1000 to convert to km and I am left with a radius of 1,645,000 km.
Obviously the radius you found can't be correct. Be careful at your conversion from ##cm## to ##km## for the radius ##r## in the end.
Also, you're slightly off to the volume: it is ##1.865625 \times 10^{28} cm^3##.
As a final comment, you can convert the density in S.I. units right off the bat and work with S.I units, making the whole thing a little easier.
Note: I used some latex inside the quote in order things to be more clear.
Likes PhyiscsisNeat
Hey, okay, good catch on the conversion, I derped :(
Looking at my metric system sheet, centimeters are 10-2 and kilometers are103. I divided my answer in centimeters by 1000 to try to put it into km. Should I have divided by 10,000 instead? If I do that, that gives me a radius of 16,453.18 km.
I am newb :(
No, you must divide by ##10^5##. In order to understand it think how many ##cm## is 1 ##km##. The answer you give is correct in order but to get there you have to divide by ##10^5##. Check again.
Likes PhyiscsisNeat
Ahhh this is frustrating. Thank you for your time.
Related to Radius of a planet with the same density as Neptune
1. What is the radius of a planet with the same density as Neptune?
The radius of a planet with the same density as Neptune is approximately 24,622 kilometers (15,299 miles).
2. How does the radius of a planet with the same density as Neptune compare to Neptune's actual radius?
The radius of a planet with the same density as Neptune is slightly larger than Neptune's actual radius of 24,622 kilometers (15,299 miles). This is due to the fact that density is only one factor in determining a planet's size, and other factors such as composition and gravitational pull also play a role.
3. Is the radius of a planet with the same density as Neptune a common measurement in planetary science?
Yes, the radius of a planet with the same density as Neptune is a commonly used measurement in planetary science. It allows scientists to compare the size of different planets based on their density, which can provide insights into their composition and formation.
4. How is the radius of a planet with the same density as Neptune calculated?
The radius of a planet with the same density as Neptune is calculated by taking the cube root of the planet's mass divided by Neptune's density. This formula is based on the relationship between density, mass, and volume.
5. Are there any known planets with the same density as Neptune?
Yes, there are several known exoplanets (planets outside of our solar system) that have a similar density to Neptune. These include Kepler-10b, GJ 1214b, and WASP-107b. However, none of these planets have the exact same density as Neptune, as each planet has its own unique composition and size.
24K
