Radius of circumference circumscribed to a triangle
In summary, the formula linking the radius of the circumference and the side of the triangle is side=radius√3. This is derived from the law of sines, which establishes a common ratio between the lengths of the sides of a triangle and the sines of its angles. This ratio is equal to the diameter of the unique circle in which the triangle can be inscribed, also known as the circumcircle. The circumdiameter, which is twice the circumradius, can be computed as the length of any side of the triangle divided by the sine of the opposite angle, according to the law of sines. This result will be the same regardless of which side and opposite angle are chosen.
greg_rack
79
Find the radius of circumference circumscribed to an equilateral triangle of side=8cm
No equations needed
At first I had no idea of how to solve this problem, but checking online I found out that there is a formula linking the radius of the circumference and the side of the triangle... the formula is:
side=radius√3
The thing is that I can't understand why is this working... which deduction have been made to derive it?
Check this out:
https://www.mathopenref.com/trianglecircumcircle.html
The law of sines establishes a common ratio for all the lengths of the sides of a triangle to the sines of its angles.
That ratio is the diameter (2 x radius) of the unique circle in which that triangle can be inscribed (circumscribed circle of the triangle).
Copied from
https://en.m.wikipedia.org/wiki/Circumscribed_circle#Other_properties
“The diameter of the circumcircle, called the circumdiameter and equal to twice the circumradius, can be computed as the length of any side of the triangle divided by the sine of the opposite angle:
{\displaystyle {\text{diameter}}={\frac {a}{\sin A}}={\frac {b}{\sin B}}={\frac {c}{\sin C}}.}
As a consequence of the law of sines, it does not matter which side and opposite angle are taken: the result will be the same.”
Likes greg_rack
Related to Radius of circumference circumscribed to a triangle
1. What is the formula for calculating the radius of the circumference circumscribed to a triangle?
The formula for calculating the radius of the circumference circumscribed to a triangle is r = (abc)/(4A), where a, b, and c are the side lengths of the triangle and A is the area of the triangle.
2. How is the radius of the circumference circumscribed to a triangle related to the triangle's angles and sides?
The radius of the circumference circumscribed to a triangle is related to the triangle's angles and sides through the law of sines and the law of cosines. These laws allow us to find the length of the triangle's sides and angles, which are used in the formula for calculating the radius.
3. What does the radius of the circumference circumscribed to a triangle represent?
The radius of the circumference circumscribed to a triangle represents the distance from the center of the circle to any of the triangle's vertices. This distance is the same for all three vertices, making it the radius of the circumcircle.
4. Can the radius of the circumference circumscribed to a triangle be negative?
No, the radius of the circumference circumscribed to a triangle cannot be negative. It is always a positive value, as it represents a distance.
5. How does the radius of the circumference circumscribed to a triangle affect the shape of the triangle?
The radius of the circumference circumscribed to a triangle does not affect the shape of the triangle. It is simply a measure of the distance from the center of the circumcircle to any of the triangle's vertices. The shape of the triangle is determined by the lengths of its sides and the angles between them.
