Radius of convergence for (1+x)^1/2
In summary, the conversation discusses finding the Taylor Series for (1+x)^1/2 and determining the radius of convergence. The solution involves finding the derivatives of the function and simplifying to obtain the Taylor Series. The conversation also includes a discussion on using the ratio test to determine the interval of convergence, with some discrepancy in the calculations. Ultimately, the conversation arrives at an expression for the Taylor Series, but the issue of taking into account the first two terms remains unresolved.
asif zaidi
56
Problem Statement:
Compute the Taylor Series for (1+x)^1/2 and find the radius of convergence
Problem Solution:
The Taylor Series expansion I get is
T(x) = 1 + (0.5*x) - (0.25*x^2)/2 + (0.375*x^3)/3! - (0.9375*x^4)/4! +...-...
So to get radius of convergence I have to find a closed solution form of the above equation and I simply am not able to come up with anything. Any pointers on this will be appreciated.
But then I was looking at the equation and saw that at least I can represent the x and the factorial portions as Sum (from 0-inf) x^i/i! and not worry about the coefficient.
If I use ratio test on this closed form, I will get the interval of convergence to be -inf to +inf. Therefore radius of convergence is +inf
Am I correct - if not please advise
Thanks
Asif
?? A closed form for the series? It is (1+ x)1/2 of course!
I have no idea how you get -inf to inf as interval of convergence. You wrote the coefficients as "0.5", (0.25", "0.375", etc. which makes me wonder if you are sure of the correct values.
The nth derivative of (1+x)-1/2, at 0, is (2n-3)!/((n-2)!2n-2) so the nth term in the sum is (2n-3)!xn/((n-2)!n!2n-2). Applying the ratio test to that does not give infinity as radius of convergence.
But you can use the "closed form", which, as I said, was exactly what you were given: (1+ x)-1/2. In general the Taylor's series of a function will converge as long as the function is "nice". Where is there a "problem" with (1+ x)-1/2? How far is that value of x from x=0? That is the radius of convergence.
I am a bit confused with the response so I will give more detail as to what I have done
First part is to find Taylor Series for (1+x)[tex]^{1/2}[/tex]
BTW, in your response you have given (1+x)[tex]^{-1/2}[/tex] so I think the 1st difference is there.
Anyway for Taylor series I do the following.
Find derivatives
f'(x) = 1/2 (1+x)[tex]^{-1/2}[/tex]
f''(x) = (1/2)(-1/2)(1+x)[tex]^{-3/2}[/tex]
f'''(x) = (1/2)(-1/2)(-3/2)(1+x)[tex]^{-5/2}[/tex]
f''''(x) = (1/2)(-1/2)(-3/2)(-5/2)(1+x)[tex]^{-7/2}[/tex]
f'''''(x) = (1/2)(-1/2)(-3/2)(-5/2)(-7/2)(1+x)[tex]^{-9/2}[/tex]
f''''''(x) = (1/2)(-1/2)(-3/2)(-5/2)(-7/2)(-9/2)(1+x)[tex]^{-11/2}[/tex]
Simplifing above gives and evaluating at 0 gives
f'(x) = 1/2(1+x)[tex]^{1/2}[/tex] = 1/2
f''(x) = -1/4(1+x)[tex]^{-3/2}[/tex] = -1/4
f'''(x) = 3/8(1+x)[tex]^{-5/2}[/tex] = 3/8
f''''(x) = -15/16(1+x)[tex]^{-7/2}[/tex] = -15/16
f'''''(x) = 105/32(1+x)[tex]^{-9/2}[/tex] = 105/32
f''''''(x) = -945/64(1+x)[tex]^{-11/2}[/tex] = -945/64
Thus Taylor Series:
T(x) = 1 + x/2 -x[tex]^{2}[/tex]/2!4 + 3x[tex]^{3}[/tex]/3!8 -15x[tex]^4}[/tex]/4!16 + 105x[tex]^{5}[/tex]/5132 - 945x[tex]^{6}[/tex]/6!64 +...
Next Step is to find an expression using [tex]\sum[/tex] (from 0-inf). And this is what I meant by closed sum. My terminology is probably wrong according to what you say. However, whenever I have done exercises to find radius/interval of convergence, I have always had an expr of [tex]\sum[/tex]. I then evaluate a(n+1)/a(n) and see it is < |1| and find interval of convergence
Any advice on how I can find the right expression and then radius of convergence.
Note: in your case if you give me (1+x)[tex]^{-1/2}[/tex] then the radius of convergence will be 1. But I don't think this this applies to (1+x)[tex]^{1/2}[/tex] case because this function is 'nice' everywhere.
Thanks
Asif
Now set x= 0:
f'(0): 1/2
f''(0): (1/2)(-1/2)
f'''(0): (1/2)(-1/2)(-3/2)
f''''(0): (1/2)(-1/2)(-3/2)(-5/2)
f'''''(0): (1/2)(-1/2)(-3/2)(-5/2)(-7/2)
f''''''(0): (1/2)(-1/2)(-3/2)(-5/2)(-7/2)(-9/2)
The sign is alternating: it's (-1)n. The denominator is a power of 2: it's 2n The numerator is 1(3)(5)(7)(9)... That would be an exponential except that it is "missing" the even integers. Okay, put them in: 1(2)(3)(4)(5)(6)(7)(8)(9)/(2)(4)(6)(8) where I have also, of course, put those same numbers in the denominator- I have multiplied numerator and denominator by the same thing in order to keep the fraction the same thing. The numerator is now obviously 9!. What about the denominator? Well, since those are all even numbers, we can factor a 2 out of each: (2)(4)(6)(8)= (2)(1)(2)(2)(2)(3)(2)(4)= 24(1)(2)(3)(4)= 24(4!). The numerator in f''''''(0) is 9!/244!. It should not be difficult to see that the general term, for f(n)(0) is (2n+1)!/2nn! Since the denominator was already 2n and the sign was alternating, f(n)(0)= (2n+1)!/[(2n(n!)2] and so the nth term in the Taylor's series is (2n+1)!/[(2n(n!)3]xn
HallsofIvy said:
Now set x= 0:
OK - I see what you are trying to do by getting 9! etc... But if I use the formula you give, it does not match
You have given f(n)(0)= (2n+1)!/[(2n(n!)2]
So if I calculate it for n=6, I get 13!/(12*6!2 = 187.6875.
However, using Taylor Series expansion, I get 14.76
However, using info you provided I was able to come up with the following form
1 + 0.5x + Sum (2-inf) [ (2n-3)! / n!(n-2)! 22n-2 ].
I did this for a few n's and got the same coefficient as Taylor Series.
But the problem is to find the radius of convergence for this, how do I take into account the 1st 2 terms (1+0.5x).
Thanks
Asif
Related to Radius of convergence for (1+x)^1/2
1. What is the radius of convergence for (1+x)^1/2?
The radius of convergence for (1+x)^1/2 is 1. This means that the series will converge for all values of x within a distance of 1 from the center point (x=0).
2. How is the radius of convergence determined for (1+x)^1/2?
The radius of convergence is determined by using the Ratio Test, which compares the absolute value of consecutive terms in the series. If the limit of this ratio is less than 1, the series will converge. In the case of (1+x)^1/2, the limit is 1, indicating that the series converges for x values within a distance of 1 from the center point.
3. What happens if x is outside the radius of convergence for (1+x)^1/2?
If x is outside the radius of convergence, the series will diverge, meaning that it does not have a finite sum. This means that the series is not a valid representation of the function (1+x)^1/2 for those values of x.
4. Can the radius of convergence for (1+x)^1/2 be negative?
No, the radius of convergence cannot be negative. It represents a distance from the center point (x=0), which cannot be a negative value. However, it is possible for the radius of convergence to be 0, which would indicate that the series only converges at the center point and does not converge for any other values of x.
5. Does the radius of convergence for (1+x)^1/2 depend on the power of x?
Yes, the radius of convergence can vary depending on the power of x in the series. In the case of (1+x)^1/2, the radius of convergence is 1, but for a series such as (1+x)^2, the radius of convergence would be 0.5, as the series converges for x values within a distance of 0.5 from the center point.
