Radius of curvature of planetary motion
In summary, the conversation discusses the motion of a smaller planet orbiting a larger one along an elliptical path. At the point of closest approach, the velocity and acceleration of the smaller planet can be calculated using polar coordinates. The equation for curvature is also discussed, with a correction made to the original equation. The final equation shows that the radius of curvature at the point of closest approach is the distance of closest approach r itself.
zalook
Suppose we have a planet of mass m orbiting a larger one of mass M along an elliptical path. If we use polar coordinates with the origin placed on the planet of mass M (focus of the ellipse) then at the instant when the smaller planet is at the point of closest approach we have:
[itex] \boldsymbol{v} = r \frac{d\theta}{dt} \boldsymbol{u_{\theta}} [/itex]
[itex] \boldsymbol{a} = - r \: (\frac{d\theta}{dt})^{2} \: \boldsymbol{u_{r}} = - \frac{G M}{r^{2}} \boldsymbol{u_{r}} [/itex]
From which we obtain:
[itex] \boldsymbol{a} = - \frac{v^{2}}{r} \: \boldsymbol{u_{r}}= - \frac{G M}{r^{2}} \: \boldsymbol{u_{r}} [/itex]
Now, if we calculate the curvature:
[itex] k = \frac{\left\|\boldsymbol{a} \times \boldsymbol{v} \right\|}{v^{3}}= \frac{G M}{r^{2} v^{2}}[/itex]
From this equation and the previous one it looks as if the radius of curvature at the point of closest approach is the distance of closest approach r itself, which is not true. I'd appreciate if you could clear this up.
EDIT: nevermind, the second equation is wrong, [itex] \frac{d^{2}r}{dt^{2}} [/itex] is not zero.
The correct equation would be:\boldsymbol{a} = - \frac{G M}{r^{2}} \: \boldsymbol{u_{r}} + \frac{v^{2}}{r} \: \boldsymbol{u_{r}}Which results in:k = \frac{\left\|\boldsymbol{a} \times \boldsymbol{v} \right\|}{v^{3}}= \frac{G M}{r^{3}}
Related to Radius of curvature of planetary motion
1. What is the radius of curvature of planetary motion?
The radius of curvature of planetary motion is the distance from the center of the planet to the point at which the planet's orbit changes direction.
2. How is the radius of curvature of planetary motion calculated?
The radius of curvature of planetary motion can be calculated using the planet's orbital period and the distance between the planet and the Sun.
3. Why is the radius of curvature of planetary motion important?
The radius of curvature of planetary motion is important because it helps determine the shape and size of a planet's orbit, as well as its speed and acceleration.
4. Can the radius of curvature of planetary motion change?
Yes, the radius of curvature of planetary motion can change as a planet's distance from the Sun, orbital speed, and direction of motion can all change over time.
5. How does the radius of curvature of planetary motion differ between planets?
The radius of curvature of planetary motion can differ between planets based on their distance from the Sun, orbital eccentricity, and mass. Planets closer to the Sun generally have smaller radii of curvature compared to those farther away.
  • Classical Physics
  • Mechanics
  • Classical Physics
  • Classical Physics
  • Mechanics
  • Classical Physics
