Radius of curvature of the trajectory of points A and B
In summary, the radius of curvature of the trajectory of point A is given by the equation ##R_A=\frac{v_A^2}{a_{nA}}##.
Davidllerenav
424
A cylinder rolls without slippage on a horizontal plane. The radius of the cylinder is equal to r. Find the radious of curvature of the trajectory of points A and B.
  • Ciruclar motion equations.
  • ##R=\frac{1}{C}##
First I drew the velocity of A and B, as well as the angular acceleration of both like this:
After that I used the formula for the radious of cuvature ##R=\frac{1}{C}=\frac{ds}{d\varphi}\Rightarrow ds=Rd\varphi \Rightarrow d\varphi=\frac{ds}{R}=\frac{vdt}{R}\Rightarrow \frac{d\varphi}{dt}=\frac{v}{R}=\omega##. Then, I used the angular acceleration formula ##a_{n}=\frac{v^2}{R}=\omega^2 R##.
After that I attempted to find the radious of A:
##v_A=\omega R_A##
##a_{nA}=\frac{v_A^2}{R_A}\Rightarrow R_A=\frac{v_A^2}{a_{nA}}=\frac{\omega^2R_A^2}{a_{nA}}##
After that I don't know whta to do, is that it? Or do I have to do something else?
I can give you a hint
You have to write the equation of a trajectory of a point of the cylinder. The trajectory is know in mathematics as cycloid.
Once you have an equation of the trajectory, use the formula for the curvature https://en.wikipedia.org/wiki/Curvature
Good luck
Your vector ##\vec v_B## in your drawing is not correct if it is meant to represent the velocity of B relative to the table. The direction you have indicated would be the direction of the velocity of B relative to the moving center C, ##\vec v_{B/C}##.
If ##\vec v_C## is the velocity of C relative to the table, then you can find ##\vec v_B## by using the relative velocity formula ##\vec v_B = \vec v_C + \vec v_{B/C}##.
Likewise, you can find ##\vec a_B## from the relative acceleration formula ##\vec a_B = \vec a_C + \vec a_{B/C}##.
After that I used the formula for the radious of cuvature ##R=\frac{1}{C}=\frac{ds}{d\varphi}##
Here, ##d\varphi## represent the change in angle of the tangent line to the trajectory when moving along the trajectory by ##ds##. ##\frac{d \varphi}{dt}## is not equal to the angular speed ##\omega## of the cylinder.
##v_A=\omega R_A##
This relation between ##v_A## and the radius of curvature at A is not correct. You can get ##\vec v_A## by using the relative velocity fomula ##\vec v_A = \vec v_C + \vec v_{A/C}##
##a_{nA}=\frac{v_A^2}{R_A}\Rightarrow R_A=\frac{v_A^2}{a_{nA}}##
This looks good. But, you cannot replace ##v_A## by ##\omega R_A##.
In summary, you can find the radius of curvature at A by using ##R_A=\frac{v_A^2}{a_{nA}}##. But you have to be careful in obtaining ##v_A## and ##a_{nA}##.
With this approach, you do not need to work with the explicit formula for a cycloid.
Alternately, as @Henryk suggests, you can get the answer using the equation for a cycloid and the general formula for the radius of curvature of a curve.
Good luck
Thanks, I'll give it a try.
TSny said:
dφdtdφdt\frac{d \varphi}{dt} is not equal to the angular speed ωω\omega of the cylinder.
Why? Isn't it the change of the angle as time pases?
TSny said:
This expression for vAvAv_A is not correct.
That is not correct beacuse I need to set the coordinate system in the table, right? It would only be correct if ti is at the center.
No, it's much simpler than that.
@Davidllerenav , think about which part of the cylinder is, momentarily, stationary.
The part that is in contact with the ground would be momentarily stationary. In this case O.
Right.
So what can you say about how quickly the distance from A to that point on the ground is changing? What does that suggest about the radius of curvature of its motion?
haruspex said:
Right.
It would be a function of time a think, right? Because the radius changes with time.
That's not what I meant. But I just realized a problem with my thinking. Proceed with the other advice while I try to fix it.
No, I think it's ok...
If point O of the cylinder is momentarily stationary, what are other parts of the cylinder doing in relation to it?
Rotating, right? It would become the center.
Yes, and with what radius for A?
I think that 2r, because it would be the diameter.
Right. What about B?
Well, I really don't know. It would be a line from O to B, and maybe I can try to make a triangle, but I don't know how.
I'm sure you'll see how with a bit more thought.
I think I got it. I can draw the velocity with respect to the center, which is tanget to the cylinder and draw the velocity of the center, it seem sthat the sum of both is the velocity of the point B with respect to the point O.
Yes, but the problem is to find the radius of curvature of the path, not the instantaneous velocity.
But can't I find the angular velocity which has the radius?
Yes, if you find the angular velocity and the linear velocity that will tell you the radius, but it does seem a long way round. Isn't B's distance from O easy to determine?
Maybe I can do the same thing I did with velocity but with position?
How far is OC? How far is BC? What is the angle between?
OC is ##r##, because it goes to the center. BC is ##2\cdot OC=2r##, am I right? The angle between them is 45 degrees.
Davidllerenav said:
BC is 2⋅OC
No, and I am really puzzled that you could think so. Are you looking at the right points?
Oh, sorry I thought about OB. Then BC has a length r too and between BC and OC the angle is of 90 degrees.
Right, so what is the distance BC?
It would be the radius.
Sorry, I meant OB.
haruspex said:
Sorry, I meant OB.
It would be ##OB=\sqrt{r^2+r^2}=r\sqrt{2}## right?
  • #31
Yes.
  • #32
haruspex said:
Yes.
So that would be the radius of curvature of point B?
  • #33
Yes.
  • #34
haruspex said:
Yes.
Ok, thanks. How do I find the radius of curvature for A?
  • #35
The distance between O and B is not equal to the radius of curvature of the trajectory of point B when B is at the position shown.
Likes Delta2
