Radius of Curvature to Correct Myopia
In summary, the focal length of the contact lens required to correct myopia is found from the Gaussian thin lens equation and it is -5.47.
TeslaCoil137
A person's eye has a near point of 7 cm. The cornea at the outer surface of the eye has a refractive index of n_c = 1.376 and forms a convex shape with a radius of curvature of R_2 = 8 mm against air. The figure below shows the same eye with a contact lens (refractive index of n_L = 1.5) mounted against the cornea such that second (right) surface matches the curvature of the cornea (i.e. R_2= 8 mm). Determine the radius R_1 of the first surface of the contact lens that will correct the near point to the normal 25 cm distance from the eye. Assume paraxial and thin lens conditions.
(1) 1/f =1/f_1 + 1/f_2, (2) 1/f_1 = (n/c -1) (1/R_1 -1/R_2), (3) 1/f_2 = (n_L -1)(1/R_2), (4) 1/u + 1/v = 1/f
The focal length of the combined lenses required to correct the present myopia is found from the Gaussian thin lens equation as 1/-7 + 1/-25 = 1/f ⇒ f= -5.47. Using paraxial optics and Fermat's principle of least time relevant equations (1)-(3) are easily found by requiring that all paths through the lens take equal time to reach the focus. Substituting (2) and (3) into (1) with the given numbers we find R_1 =-17.98 cm.
The object distance is real +25 cm, but I do not think this is the correct approach.
The applicable formula that I could find is
n/a + n''/b' = (n'-n)/r + (n''-n')/r'
where the object distance for the first surface of the contact lens (curvature radius r) being a, and the final image being formed at b' by the second surface (curvature radius r') and the refractive indices n (air), n' (contact lens), and n'' (fluid)
This was derived from the formula for refraction at a single spherical surface
n/a + n'/b = (n'-n)/r
being applied at both surfaces and assuming that the distance between the two surfaces is negligible
Maybe you are suppose to derive the 1st formula?
Ok, thank you. So what's the conceptual issue I have that lead to my approach?
Well, for one (4), Gauss's equation for thin lenses, assume that the lens is in air.
What you can also do it apply the second equation in my previous post at both surfaces if you do not have the first one in you handbook and then assume that the distance between the two surfaces are negligible.
FAQ: Radius of Curvature to Correct Myopia
What is the definition of "Radius of Curvature to Correct Myopia"?
The radius of curvature to correct myopia refers to the curvature of a corrective lens that is used to correct nearsightedness. It is a measure of how much the lens bends light to focus it properly on the retina.
How is the radius of curvature determined for myopia correction?
The radius of curvature for myopia correction is determined by the power of the corrective lens and the shape of the cornea. The power of the lens is measured in diopters, and the shape of the cornea is measured with a keratometer or corneal topographer.
What is the relationship between the radius of curvature and myopia?
The radius of curvature is directly related to myopia, as it determines the amount of bending that is needed to properly focus light on the retina. A steeper curvature is needed for higher degrees of myopia, while a flatter curvature is needed for lower degrees of myopia.
How does the radius of curvature affect the clarity of vision in myopia?
The radius of curvature is crucial in correcting myopia because it determines the amount of light bending needed for clear vision. If the curvature is too steep or too flat, it can cause blurry or distorted vision. The correct curvature is essential for clear and comfortable vision.
Can the radius of curvature change over time in myopia?
Yes, the radius of curvature can change over time in myopia. This can occur due to natural changes in the shape of the cornea, or it can be affected by external factors such as eye strain or improper use of corrective lenses. Regular eye exams are important to monitor any changes in the radius of curvature and adjust the corrective lenses accordingly.
