- 8,925
- 680
- TL;DR Summary
- Rail gun - point of application of force?
A rail gun exerts an electromagnetic force on a projectile. The only moving object is the projectile, so is the point of application of force moving?
Update - For others reading this thread, after a re-think on this, for linear motion (as opposed to angular motion), the point of application of force is not a factor in calculating change in momentum or energy, although it might be interesting to some.
What started me on this was similar to jbriggs444's post#19: Although work is often defined in terms of the dot product of a force and the displacement of the point of application of said force, that definition is not, in fact, correct. More correct would be the dot product of the force and the displacement of the material at the point of application of said force.
However, for linear motion, it seems to me that the point of application of force doesn't matter when calculating change in momentum or energy for linear motion, only the requirement that the linear force be applied to the object somewhere, even if that point of application of force is moving with respect to the object. The example I used below is a vehicle accelerating on a flat surface with finite mass and free to move linearly, using the center of mass of vehicle and surface as an inertial frame of reference. The change in momentum of the flat surface is the {backwards force exerted by the tires of the vehicle} · time, and the change in energy is {backwards force exerted by the tires of the vehicle} · {distance the flat surface moves}, even though the point of application of force is moving with respect to the flat surface.
