Understanding the Raising and Lowering Operator: A Scientific Analysis
In summary, the proof for the equation $$\hat a|n\rangle = k|n-1\rangle$$ begins with noting that ##k## is a real and positive constant. This convention is necessary due to the fact that eigenstates are only defined up to a complex phase factor. By using the equation $$\hat a^{\dagger}\hat a |n\rangle = n|n\rangle$$ and the normalization of ##|n\rangle##, we can see that $$\langle n|\hat a^{\dagger}\hat a |n\rangle = n$$. This can also be evaluated using the important identity $$\langle \psi |\hat X |\phi \rangle = \langle \phi
VVS2000
150
TL;DR Summary
I was reading up on linear harmonic oscillator and here when they define 2 new operators for solving the problem.
I still am finding it difficult how they ended up with the relation mentioned in the grey box, describing how the above mentioned operators act on given eigen state
Thanks in advance
The proof is not immediately obvious. We start by noting that $$\hat a|n\rangle = k|n-1\rangle$$for some constant ##k##, where we take ##k## to be real and positive by convention. Note that eigenstates are defined only up to a complex phase factor, so we need this convention.
Next, using $$\hat a^{\dagger}\hat a |n\rangle = n|n\rangle$$ and the normalisation of ##|n\rangle## we see that$$\langle n|\hat a^{\dagger}\hat a |n\rangle = \langle n| n|n\rangle = n$$Finally, we evaluate the LHS a different way: $$\langle n|\hat a^{\dagger}\hat a |n\rangle = \langle n|\hat a^{\dagger}k|n-1\rangle = k\langle n-1|\hat a|n\rangle^* = k\langle n-1|k|n-1\rangle^* = k^2$$using the normalisation of ##|n-1\rangle## and the important identity: $$\langle \psi |\hat X |\phi \rangle = \langle \phi |\hat X^{\dagger} |\psi \rangle^*$$which applies for all vectors and operators. That leads to the required equation $$k^2 = n$$
Likes Omega0, Twigg, vanhees71 and 1 other person
PS it would be a good exercise to do the proof for ##\hat a^{\dagger}## yourself.
Likes Twigg and vanhees71
Yeah I will try it for sure,
Thanks!
FAQ: Understanding the Raising and Lowering Operator: A Scientific Analysis
What is the "raising and lowering operator" in mathematics?
The raising and lowering operator is a mathematical concept used in quantum mechanics to describe the behavior of physical systems. It is represented by the symbols "a" and "a†" and is used to raise or lower the energy levels of a system.
How is the raising and lowering operator used in quantum mechanics?
In quantum mechanics, the raising and lowering operator is used to describe the behavior of physical systems, such as atoms and molecules. It is used to calculate the energy levels of a system and to determine the probabilities of different outcomes in a measurement.
What is the relationship between the raising and lowering operator and the Heisenberg uncertainty principle?
The raising and lowering operator is related to the Heisenberg uncertainty principle, which states that the more precisely the position of a particle is known, the less precisely its momentum can be known, and vice versa. The raising and lowering operator is used to calculate the uncertainty in the position and momentum of a particle.
How does the raising and lowering operator affect the behavior of particles?
The raising and lowering operator affects the behavior of particles by changing their energy levels. When a particle interacts with the raising or lowering operator, its energy level is either increased or decreased. This plays a crucial role in determining the behavior of particles in quantum mechanics.
What are some real-world applications of the raising and lowering operator?
The raising and lowering operator has many real-world applications, particularly in the fields of quantum mechanics and atomic physics. It is used to study and understand the behavior of atoms and molecules, and it has also been applied in the development of technologies such as lasers and transistors.
