Raising humidity - how much water is needed?
In summary: The best way to control humidity is to use an electronic device that switches the cooler on and off automatically.
SentinelAeon
31
Hello, my first post here so nice to meet you all :)
I have a question. Let's take a small room, about about 16 m^3 (172 feet^3). This room has a very low humidity, especially in the winter. It is around 35%, i would like to raise it to 55% with a custom made swamp cooler. I am trying to figure out how much water would be needed for that in order to figure out how big of a container with water i need to have, to only add water every few months. So i need 2 things:
1) How much water it takes to raise humidity in the room from 35% to 55% if we assume there is no fresh dry air coming in
2) A good way to calculate how much fresh air is actualy coming into the room if we assume that during the winter windows are mostly shut (cold air from outside will lower the humidity fast, so we want to avoid opening windows except maybe few minutes a day)
I know this is really difficult to answer but i am looking really for an aproximation. to know if i need 10L container, 20L, 30L and so on.
One important factor that you haven't mentioned is the temperature - that affects the quantity of water the air will hold at any given relative humidity. But with that information, you'll find tables online that let you calculate the amount of water you'll need to add.
How do you plan to control your swamp cooler so it won't push the humidity above your target 55%?
Is there any possibility of losing moisture to condensation on the windows or other surfaces that will be cooler than the room?
Likes Lnewqban
I plan to control the humidity with switching the cooler on/off automaticly with my simple esp8266 board. The temperature, its hard to say, i would say about 21C during winter and around 26C in the sumer. As for condensation i am not sure how much is lost.
Search for a psychrometric chart. The psychrometric chart shows the amount of water per cubic meter of air at any combination of temperature and humidity. Find the amounts of water at the two humidities, subtract, multiply by the volume of the room, and the result is how much water you need to add.
You will find that adding that much water will raise the humidity by the desired amount, after which the humidity will start to decrease. All rooms have air leakage. The amount of water that you need to continuously add in order to maintain the humidity at your desired level is proportional to the amount of air leakage and the humidity of the outside air.
Indoor humidity in cold weather should be low enough that you do not get condensation. Condensation causes rot and mold, both of which are bad.
Likes Lnewqban
FAQ: Raising humidity - how much water is needed?
1. How much water should I add to raise humidity levels?
The amount of water needed to raise humidity levels depends on the size of the room and the current humidity level. A general rule of thumb is to add 1-2 cups of water for every 100 square feet of space. However, it's important to monitor the humidity level and adjust accordingly.
2. Can I use tap water to increase humidity?
Yes, tap water can be used to increase humidity levels. However, it's important to note that the minerals and chemicals in tap water can leave residue on plants and surfaces. It's recommended to use distilled or filtered water to avoid any potential issues.
3. How often should I add water to maintain humidity?
This will depend on the climate and the type of humidifier being used. In general, it's recommended to check and refill the water tank every 1-2 days. If using a humidifier with a larger tank, it may only need to be refilled once a week.
4. Can I over-humidify a room?
Yes, it is possible to over-humidify a room. This can lead to mold growth and other issues. It's important to monitor the humidity levels and adjust accordingly. A humidity level between 40-60% is ideal for most plants and humans.
5. Are there any other methods to increase humidity besides adding water?
Yes, there are other methods to increase humidity levels. These include using a humidifier, placing bowls of water around the room, and misting plants with water. You can also try placing a tray of water near a heat source, such as a radiator, to increase the humidity in the room.
