Raising to the power of 0 or 1
  • I
  • Thread starter blueridge
  • Tags
    Explanation
blueridge
I know that any number (except for zero), any variable and any term raised to the zero power is 1. I don't know the reason why this is true. Can someone explain why?
Samples:
59^0 = 1
R^0 = 1
(a + b)^0 = 1
Mathematics news on Phys.org
I know that any number, any variable and any term raised to the first power equals itself. I don't know the reason why this is true. Can someone explain why?
Samples of what I mean:
45^1 = 45
x^1 = x
(y + 3)^1 = y + 3
Moderator's note: I have merge the two questions because they are closely related.
Ok.
For nonzero ##a##, ##a^0=1##, because
$$\frac{a^n}{a^n}=a^{n-n}=a^0.$$
For any ##a##, ##a^1=a##, because
$$a^1\cdot a^1=a^{1+1}=a^2.$$
Likes pinball1970, blueridge and mcastillo356
Can you explain in words why a^0 = 1 and a^1 = a? Your reply is a textbook definition. I can look it up myself. Know what I mean?
##a^n## is 1 multiplied by ##a## ##n## times. When ##n=0##, that is just 1. When ##n=1##, that is ##1 \cdot a = a##.
Likes blueridge and Mayhem
If we don't define them that way (and also define [itex]a^{-1} = 1/a[/itex]) the index law [itex]a^{n+m} = a^na^m[/itex] does not hold for all integer [itex]n[/itex] and [itex]m[/itex].[/i]
Likes blueridge
Does this also apply to numbers and terms?
For example, 5^0 = 1 and 5^1 = 5.
Another example is (a + b)^0 = 1 and (a + b)^1 = a + b.
Yes?
What do you mean if we don't define them that way?
blueridge said:
59^0 = 1
Huh? You are asking us what you say you already know.
I am asking for a clear, concise, to the core explanation of why a^0 = 1 and a^1 = a. This is all I am asking. This is not an abstract algebra problem.
He means if we define them a different way.
Don't be rude.
Let's try again from the start.
You know that ## a^3 = a(a^2) ## and ## a^4 = a(a^3) ##, yes? These are just examples of a general definition (an inductive definition) ## a^n = a(a^{n-1}) ##: in the first example we have used ## n = 3 ## and in the second example ## n = 4 ##.
Now what happens if we take ## n = 2 ##?
$$ \begin{align}
\nonumber a^2 =&\ a(a^{2-1})\\
\nonumber a^2 =&\ a(a^1)\\
\nonumber \frac{a^2}a =&\ \frac{a(a^1)}a \\
\nonumber \left( \frac a a \right)a =&\ \left( \frac a a \right) a^1 \\
\nonumber a =&\ a^1 \\
\nonumber a^1 =&\ a
\end{align}
Now you try this taking ## n = 1 ##.
Likes berkeman and blueridge
Don't be rude.
$$ \begin{align}
\nonumber a^1 =&\ a
\end{align}
Perfectly done.
Or consider: ##a^0 *a^0=a^{0+0}=a^0##. It follows ##a^0=1##.
Likes blueridge
Very good.
Likes WWGD
##a^n## is an abbreviation for ##a^n=\underbrace{a\cdot a\ldots a}_{n-times}## so ##a^1=a## and ##a^0## is an empty product and equals the neutral element of multiplication, the ##1.##
The same holds for empty sums that are equal to the neutral element of addition, the ##0.##
\sum_{\substack{k=1\\1\nmid k}}^n k=0
Thread closed as this new member has been banned.
