MHB Raju had 5 times as much money as Ann. How much did Raju have at first?
  • Thread starter Thread starter Johnx1
    Money
Raju and Ann saved a total of $1560, with Raju initially having five times as much money as Ann after giving her $50. The equations established were R + A = 1560 and R - 50 = 5(A + 50). By substituting A with (1560 - R) in the second equation, it was determined that R = 1350. Thus, Raju initially had $1350 before giving Ann $50. The calculations confirmed the solution and clarified any confusion regarding the math involved.
Johnx1
Raju and Ann saved a total of 1560 dollars. After Raju gave Ann 50 dollars, Raju had 5 times as much money as Ann. How much did Raju have at first?Number of dollars saved = R
Number of dollars saved = A
1) We know Raju and Ann saved 1560 dollars
R + A = 1560
2) (i got confuse at this part) Raju gave Ann 50 dollars, Raju had 5 times as much money as Ann
R = 5A (not sure if this is the correct way to do it)So then I did => 5A + A = 1560. So A = 260.
Then, I put it back to R = 5A, and then I added 50. So the answer is R = 1350.
Mathematics news on Phys.org
After Raju gave Ann 50 dollars Raju had \(R-50\) and Ann had \(A+50\), so we want:
$$R-50=5(A+50)$$
Now, as you observed:
$$R+A=1560\implies A=1560-R$$
And so we can now substitute into the first equation to get an equation in \(R\) only:
$$R-50=5((1560-R)+50)$$
Solving this equation, you will indeed find \(R=1350\).
$$R-50=5(A+50)$$
Thank you for this.
When I went back to this question, I had a feeling that I was making math up. Thanks again.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
