Random set of N points in a unit disc, what is the average nearest distance
In summary, the radius to the random point b from a is proportional to the area of the annular region centered on a.
Spinnor
431
Pick a random set of N points from the unit disc. Calculate the distance between all pairs of points and call the smallest value r. Do this calculation for many such sets. Please give me a hint how to estimate what the average value of r is. I guess a computer program could quickly come up with an accurate estimate as long as N is not too big?
Thanks!
If you don't need an analytic solution (and I don't know if one exists for general N) a computer simulation is a nice approach.
For very large N there are good analytic approximations.
Would 115 billion be considered a large number in this case?
I guess my 2 dimensional problem simulated on a computer could be simplified by doing the 1 dimensional problem on a computer, N random points on the unit interval, coming up with r and then inferring that for the 2 dimensional case r should be approximately (or exactly?) √2 times r for the 1D problem?
Thanks!
Thanks!
You need to increase the number of repetitions to get more accurate results, not ##N##. What you need to do is to first generate ##N## random points, such that distance from the center ,say (0,0) is less than or equal to 1. This means that ##\sqrt{r_1^2+r_2^2}\leq 1##, where ##\mathbf{r}=(r_1,\,r_2)## is a point in the unit disk. I guess how you can do this, is first to generate ##N## random variables in the interval ##[0, 1]## that represent ##r_1##, and then generate another ##N## random variables between ##[0,\sqrt{1-r_1^2}]## that represent ##r_2##. Now you have ##N## random points on a unit disk. Then you find the pair distance of all points and select the minimum, and store it. Repeat this process say ##K=10^5## times. At the end add all the minimum distances from all trials, and divide it by ##K##. This way you get the average minimum distance. Maybe there is another simpler way, but this what comes to mind now.
Likes Spinnor
Yes.
Keep in mind that the distribution of what you want to study is not uniform.
Also keep in mind that (a) protons are not point particles, (b) the bunches collide with a non-zero crossing angle and (c) there are many collisions per bunch crossing.
For a uniform distribution that should be a reasonable approximation.
Likes Spinnor
Thank you all your corrections. So if I used the numbers for focused beam bunches, bunch diameter of order several millimeters and a bunch number of a hundred billion protons should give us a r minimum of order the proton radius? Protons need to be pretty close to interact strongly?
Thank you for your help. Need to look into free easy to use math calculating software.
That is way too much.
No as they don't have to overlap to interact and they are not pool balls with a single sharp border anyway.
We have much more accurate numbers for the proton radius from other measurements. Overall LHC cross sections don't help with that.
So back to the original math question. I think I have a solution and would appreciate flaws in my approximation pointed out.
If we have N points we then have (N-1)N/2 distinct pairs of points. Focus on one pair of points and call them a and b. If I give you the coordinates of a then you could say that because b is random it could be anywhere in the unit disc. divide the unit disc into angular regions centered on point a. These annular regions do not form complete annular rings unless point a was at the center of the unit disc, consider this an error in my approximation a value I think will be between approximately between 2 and 1/2, brain is too fuzzy to figure if the error factor is larger or smaller than 1. Call the radius to the random point b from a, r_i. The probability that the random point b is in a particular annular region is proportional to the area of the annular region. Considering all pairs of points there will be (N-1)N/2 values of r_i. Randomly distribute (N-1)N/2 points about point a. The density of points is the number of points divided by the area of the unit disc, and is (N-1)N/2]/π, call that ρ. Use this density to calculate the minimum value of r, r_min such there is likely one point in an annular region centered on point a with radius r_min. We want,
Density of points times area of circular region of radius r_min = 1
[(N-1)N/2]/π X π(r_min)^2 = 1 or,
(r_min)^2 ≅ 2/[(N-1)N/2] for large N
r_min ≅ √2/N
Extrapolating, in D dimensions r_min ≅ √D/N Edit, unless I can come up with an argument for the D dimensional case let's forget it for now.
Edit, the factor of √2 should be 2, simple math error.
So at this point I should step back and ask myself, should the answer scale as 1/N. Maybe you smarter guys out there can argue yes or no I do not know.
Thanks for your help!
##r_{min} = \frac{\sqrt{2}}{N}## for a unit disk looks good. Edge effects are negligible, so the shape (disk) doesn't matter.
We can generalize it to ##r_{min} = \frac{\sqrt{2A}}{\sqrt{\pi} N}## for an area A that is not too fractured.
In d dimensions a point will have an expected ##c x^d N## points within a radius x where c is some numerical constant depending on the volume of the unit ball in d dimensions. To estimate the rmin let this value be 2/N: ##\frac{2}{N} = c r_{min}^d N## or ##r_{min}=\left(\frac{2}{cN^2}\right)^{1/d}##.
You can see the curse of dimensionality here. ##r_{min} \propto N^{-2/d}##. For large d the radius will stay quite large even for large N.
Likes Spinnor
As a general result, assuming each point comes from the same distribution, i.e., the points ##p_1,...,p_N## are IID RVs, then the distribution of the minimum
## Min (p_1,p_2,...,p_N) ## is given by ##P(Min(p_1,...,p_N)<y)= 1- (1-\phi)^N ## , where ##\phi## is the cdf.
Likes Spinnor
WWGD said:
As a general result, assuming each point comes from the same distribution, i.e., the points p1,...,pNp1,...,pNp_1,...,p_N are IID RVs, then the distribution of the minimum
Min(p1,p2,...,pN)Min(p1,p2,...,pN) Min (p_1,p_2,...,p_N) is given by P(Min(p1,...,pN)<y)=1−(1−ϕ)NP(Min(p1,...,pN)<y)=1−(1−ϕ)NP(Min(p_1,...,p_N)ϕϕ\phi is the cdf.
Does the above result agree with that of mfb, I don't see it right now? I will start here, Cumulative distribution function,
https://en.wikipedia.org/wiki/Cumulative_distribution_function
Can you point to a link or translate "IID RVs"?
Thanks!
Would that be 2 dimensional random values?
Thanks!
Sorry for my laziness :). This stands for Independently, Identically Distributed Random Variables, a condition assumed in some results like the Central Limit Theorem and others.
Likes Spinnor
They are not independent - we always have two points with the smallest distance to a neighbor. I would expect the approach with independent distributions to miss a factor sqrt(2) in the result.
Likes WWGD and Spinnor
FAQ: Random set of N points in a unit disc, what is the average nearest distance
What is a random set of N points in a unit disc?
A random set of N points in a unit disc refers to a collection of N points that are randomly distributed within a circle with a radius of 1. These points can represent any type of data, such as coordinates, measurements, or values.
How is the average nearest distance calculated for a random set of N points in a unit disc?
The average nearest distance is calculated by finding the distance between each point and its nearest neighbor, and then taking the average of all these distances. This can be done using a mathematical formula or through a computer program.
What is the significance of the average nearest distance in a random set of N points in a unit disc?
The average nearest distance is a measure of how spread out the points are within the unit disc. A smaller average nearest distance indicates a more clustered distribution, while a larger average nearest distance indicates a more dispersed distribution.
Can the average nearest distance be used to determine the pattern or structure of a random set of N points in a unit disc?
Yes, the average nearest distance can provide insight into the pattern or structure of a random set of N points in a unit disc. For example, a regular or periodic pattern would result in a smaller average nearest distance compared to a random or chaotic pattern.
How does the number of points (N) affect the average nearest distance in a random set of points in a unit disc?
The number of points (N) has a direct impact on the average nearest distance. As the number of points increases, the average nearest distance tends to decrease, indicating a more clustered distribution. However, this relationship may vary depending on the specific distribution of points within the unit disc.
