Random transfer in entanglement
In summary, entanglement does not violate relativity because there is no information transferred. The reasoning being Bob and Alice only get randomness even if there is correlation. But can random energy be transferred as it is still random? For example. Entropy decreasing at one place and increasing at another place in the entangled ends? What experiments have discounted (or proven) this?
fanieh
274
It is said that entanglement doesn't violate relativity because there is no information transferred. Ther reasoning being Bob and Alice only get randomness even if there is correlation. But can random energy be transferred as it is still random? For example. Entropy decreasing at one place and increasing at another place in the entangled ends? What experiments have discounted (or proven) this?
Or random energy transfer in the entangled ends. For example. Bob in Europa. Alice on earth. Alice will transfer heat to the Bob location in the moon Europa. Bob won't be able to get any information because Alice would send the heat random. Therefore can entanglement be used to teleport heat to another location?
No.
secur said:
No.
You are not sending information but random correlations.. please show an experiment that discounted that even sending random correlation is not allowed.
Put a red slip in an envelope, green in another. Open one and you automatically know the other. Its just correlated and that is all the this Bell-EPR stuff is. It just has slightly different statistical properties. Nothing is transferred - you simply correlated the systems. If you insist QM is like the red and green slips that remain red and green at all times then Bell says something is transferred - but only if you insist its like that. Don't insist - no problem.
Read Bells original paper where red and green slips have been replaced by Bertelmans socks:
https://cds.cern.ch/record/142461/files/198009299.pdf
Thanks
Bill
Likes vanhees71
No. This answer should be worked out, theoretically, using QM formalism. Given QM is one of many theories used in science I would have thought proposing a new model of how the universe works would be needed to accommodate your thought experiment.
Thanks
Bill
They have setup where this can be disproven.. they showed that prior to measurement, the red and green slip doesn't even exist in the envelope. Something about Bell's Inequality equation that is violated. I'll take a look at it later and let you know when I found the reference.
There is no experiment ever that has shown for red and green slips they did not exist prior to measurement - that would be classically absurd and slips of paper are classical objects.
What Bell shows is if you want properties to exist prior to measurement then you need FTL. QM is silent on such things - but places restrictions. Bell and Kochen-Specker are the main ones.
It would be wise if using experimental evidence to support a position to actually reference the experiment.
Thanks
Bill
Thanks
Bill
Yes, Bell and Kochen-Specker are the main ones. But earlier.. why did you that "Put a red slip in an envelope, green in another. Open one and you automatically know the other. Its just correlated and that is all the this Bell-EPR stuff is"? It's not Kochen-Specker but the old argument by Einstein handled already by Bohr nearly a century ago.
We don't really need to do an experiment to disprove this. The observed statistics at one end are unaffected by measurement at the other - so there is no experimental way to detect a 'decrease' of entropy at either end. As far as the endpoints are concerned there is nothing that can be measured at that endpoint that will tell whether an experiment at the other endpoint has been performed or not - it's only when we compare the results do we see the correlation.
As Bhobba said - it's simply a pre-existing correlation - nothing is 'transferred' in the measurement process.
Likes vanhees71 and bhobba
Its a correlation like Bell. Simply another example of the Bertelmans socks type situation which is also a correlation. That's all EPR, Bell etc is. It just has statistical properties different to classical - but that changes nothing - you know one and hence the the other because they are correlated. No information etc passed. With one caveat - if you want it to be like Beterlmans socks or the slips of paper and have properties at all times then FTL communication is required - but only if that is what you want.
If you want to discuss if energy is passed you need to reference a particular interpretation like BM. We have at least one expert here in it - but I am not one.
Thanks
Bill
Likes vanhees71
Thanks
Bill
Ok. No information is passed because the spin up or spin down properties don't exist before measurement.. but can't we say the correlation is caused by information in the wave function that is omnipresent? There is still information involved that is holistic.
You can numb it down by saying the wave function is not real and there is not even information that is involved.. but the simple fact there is correlation means there should be information involved.
I think you need to spell out the detail of EXACTLY what you mean.
The correlation is usually a result of conservation principles.
Thanks
Bill
Thanks
Bill
Correlation in the Bell Aspect-like experiments can be changed or the setup influenced after the photons already left the emitter.. so the correlations involved is really something not classical (I think everyone knows this). Do you claim the Aspect correlation really classical and just some conservation principles? please elaborate your context.
You seem to be jumping all over the place,
I specifically claimed:
If you don't get to the point you are trying to make then the mods will, correctly, shut this down.
Thanks
Bill
I specifically claimed:If you don't get to the point you are trying to make then the mods will, correctly, shut this down.
Thanks
Bill
It just has slightly different statistical properties... but there is correlation that can be adjusted instantaneous as per Aspect experiment. What I was describing is the standard belief. Maybe you also agree with me and we just have semantics mismatched. What is your point anyway (please get to the point)?
I was explicit.
This is my last comment. Its simply a correlation. No random energy is transferred.
Thanks
Bill
Likes vanhees71
bhobba said:
I was explicit.
Thanks
Bill
Ok. I got your ideas anyways. I was thinking if there are ways for energy to be transferred.. but you said for the Bohmians.. energy may be passed. So let's give the floor to the Bohmians.
Yes, but I think that view depends on some assumption about the 'reality' of the wavefunction. It is the view to which I subscribe - but I also recognize the serious limitations with this perspective.
If we work out the mutual information of the entangled state we find it's 2 bits. A classical 'Bertlmann's socks' type of correlation has a mutual information of 1 bit.
The quantum state permits stronger correlations than a conventional classical counterpart of that state. I would view this by saying the quantum entangled state contains twice as much information in its correlation and see the things we can do with entanglement as a consequence of this extra information resource - but this 'ontic' perspective is not necessary.
One thing we can say is that a hidden variable model has to access at least 2 bits of randomness if it is to reproduce the predictions of QM (we know this because spin-x and spin-z measurements at either end generate 2 bits of entropy and a hidden variable model has to reproduce ALL the predictions of QM not just the highly correlated ones) - so any hidden variable model based on a single binary random variable will not achieve its goal.
We can attempt to view things in a holistic and ontic way by thinking of the collapse of some wavefunction caused by measurement at either end (and ignore the obvious relativistic problems) but there is no possibility of using this process to transmit information. In other words there can be no measureable consequence that will inform someone at one end whether an experiment has been done at the other. That includes no measureable consequence for 'energy' or 'entropy' - so to answer your question there's no transfer of anything physically measurable.
We've supplied a number of "no" answers in this thread, and it is time to close it.
As always, it can be reopened to allow further on-topic and helpful points to be made.
Likes vanhees71
FAQ: Random transfer in entanglement
What is random transfer in entanglement?
Random transfer in entanglement refers to the process of transferring information between two entangled particles without any predetermined pattern or order. This transfer is completely random and cannot be predicted beforehand.
How does random transfer work in entanglement?
In random transfer, two particles become entangled through a process called quantum entanglement. This means that their properties, such as spin and momentum, become correlated. When one particle is measured, the other particle will have the opposite value, regardless of the distance between them. Random transfer occurs when information is transmitted between these particles through quantum communication protocols.
What is the significance of random transfer in entanglement?
Random transfer is significant because it allows for secure communication between two parties. Since the transfer is completely random and cannot be predicted, it is impossible for an eavesdropper to intercept and decipher the information being transmitted. This makes it a valuable tool for quantum communication and cryptography.
Can random transfer in entanglement be used for practical applications?
Yes, random transfer in entanglement has several practical applications. It is commonly used in quantum communication for secure data transmission. It is also being studied for use in quantum computing, as the randomness of the transfer can be harnessed for generating random numbers, a crucial element in many quantum algorithms.
Are there any challenges or limitations to random transfer in entanglement?
One challenge with random transfer in entanglement is maintaining the entanglement between particles over long distances, as any external interference can disrupt the entanglement. Another limitation is the current difficulty in creating and controlling entangled particles, making it challenging to scale up the use of random transfer for practical applications.
