Randomness of radioactive decay
In summary: A."In summary, the Quantum Zeno effect is a phenomenon in quantum mechanics in which the probability of a system's state collapsing into a particular eigenstate after repeated measurements decreases with time. This decrease is called the quantum Zeno effect.
mario0815
Hi everyone!
I have two questions about radioactive decay that some of you might be able to answer (I'm a mathematician and no physicist by the way). The first one is very general:
As I understand it the time at which a single instable atom decays is believed to be a truly random process. But what about the type of decay that occurs? For example if you lookup Technetium-99m in wikipedia it says under Nuclear properties:
"Tc-99m decays mainly by gamma emission, slightly less than 88% of the time."
and
"The remaining approximately 12% of 99mTc decays are by means of internal conversion, resulting in ejection of high speed internal conversion electrons in several sharp peaks (as is typical of electrons from this type of decay) also at about 140 keV"
Is it also truly random which type of decay will occur in the same sense it is random when it will occour? Should these values 88% and 12% be valid under all circumstances or are there any environmental factor that are known or at least believed to influence them? For example it is known that observing a single instable atom (testing if it has decayed) will collapse its wave function and in some sense "reset the timer". So an atom that is constantly observed is believed to never decay which means that the decay rate is only true for unobserved atoms. Is there anything that is believed to influence the type of decay as well? (if it even is truly random)
My second question is very specific and relates to the mentioned Technetium-99m. Does anyone happen to know where I can find the most accurate chances of it decaying one or the other way that are known from experiments or follow from theory. Do these chances (and also the decay rate) even follow from theory or can they only be found experimentally?
Yes, branching ratios are also random in terms of which one will occur. Just like if I toss a coin, 50% of the time it is heads, so I'd say that the heads branching ratio is 50%.
The caveat is for isotopes that decay via Electron Capture or Internal Conversion (your 99mTc example was prescient!). In those cases, the decay is due to the interaction between the electrons around the nucleus, so if you ionize the atom, you perturb the decay rate. This is often subtle (most IC or EC is due to the innermost electrons). If you fully ionize 7Be, it will never decay as the only possible decay channel is through EC.
The National Nuclear Data Center is where you will find information like the decay of 99mTc. It is home to the "accepted" data for every isotope. Since 99mTc is very important for medical uses, the half-life and branching ratios are well studied. http://www.nndc.bnl.gov/nudat2/chartNuc.jsp Search 99Tc in the search box, and click "level scheme" or "decay radiation". Looks like there's also a very small chance that beta minus decay can occur! The IT vs B- branching ratios are shown here to 6 significant figures!
In nuclear physics, our theoretical models aren't good enough to give us that sort of accuracy.
Likes zoki85
There is no timer. That's the point of "random". It can decay within a nanosecond - and the probability to decay within the next nanosecond (if it still exists) is always the same.
It is possible to make rough theoretical predictions for branching ratios, but usually it is easier to measure them.
Likes bhobba and e.bar.goum
I don't know that this environmental factor affects the branching ratios, but gravity (GR) does affect the half-life of any decay reaction. In other words, there are relativistic considerations since time dilates in its presence. This is relevant in collider experiments.
Likes bhobba
Thank you all for your replies!
On "There is no timer" from mfb:
If that is true then I don't understand the Quantum Zeno effect:
http://en.m.wikipedia.org/wiki/Quantum_Zeno_effect
"Consider a system in a state A, which is the eigenstate of some measurement operator. Say the system under free time evolution will decay with a certain probability into state B. If measurements are made periodically, with some finite interval between each one, at each measurement, the wave function collapses to an eigenstate of the measurement operator. Between the measurements, the system evolves away from this eigenstate into asuperposition state of the states A and B. When the superposition state is measured, it will again collapse, either back into state A as in the first measurement, or away into state B. However, its probability of collapsing into state B, after a very short amount of time t, is proportional to t², since probabilities are proportional to squared amplitudes, and amplitudes behave linearly. Thus, in the limit of a large number of short intervals, with a measurement at the end of every interval, the probability of making the transition to B goes to zero."
If there is no timer that stores the time since the last measurement then why are the chances of decay smaller after a measurement and why can the decay be slowed down or even stopped this way?
To e.bar.goum:
Thank you for the link! But I really have problems understanding the data. So there are three possible ways it can decay? But where can I find the chances for each case?
To DrChinese:
That's a good point but I don't see why gravitation would also influence the chance for a certain decay type.
Gravity is not relevant for collider experiments. Special relativity is, but this is not an issue - you can simply go to the rest frame of the particle again.
The quantum zeno effect needs quite special conditions (in particular, non-exponential probability evolutions). You don't get it for nuclear decays. There are other processes that have timer-like state evolutions.
That never occurred to me - but now I think about it it must be true.
Really appreciate the insight.
Thanks
Bill
Thanks
Bill
It should be pointed out that it's SR not GR that's in play here.
But no only is it relevant in collider experiments, it's actually actively exploited at places like the ESR at GSI. https://www.gsi.de/en/start/forschung/forschungsfelder/appa_pni_gesundheit/atomphysik/research/experimental_facilities/esr.htm
Hmmm. I haven't seen calculations on the size of GR corrections but any process that involves time must be different in a gravitational field compared to the conceptual inertial frame of SR.
Thanks
Bill
Thanks
Bill
Sure, but the issue in particle accelerators is that we're accelerating particles to relativistic speeds. (~65% of the speed of light at GSI, 99.9999991% at LHC etc), not that they're in a gravitational potential. I've never come across a nuclear physics problem where anything other than corrections as per SR are used (happy to be corrected!).
See for example, http://www.researchgate.net/publication/223833956_Rare_ISotopes_INvestigation_at_GSI_%28RISING%29_using_gamma-ray_spectroscopy_at_relativistic_energies
Measurements of gravitational redshift via the Mößbauer effect? Well, that is a very special application directly designed to see effects of gravity.
Time dilation and other SR effects are taken into account in accelerator experiments all the time. Usually they are so dominant nonrelativistic approaches would be pointless.
Ok, given. (And that's very neat.)
Unless you're doing low-medium energy nuclear physics, rather than particle physics. Most of the time, you're in the nonrelativistic regime there.
Thanks for correcting my poorly written comment, which mixed GR and SR references. A radioactive sample will decay at different rates in different gravitational fields, which has nothing to do with a collider.
Thanks
Bill
Yeah that's why I posted. It's very interesting that even a process like radioactive decay would be affected by nearby mass. It makes sense of course but I find it very cool anyway.
mfb: Thanks for correcting my poorly written prior post. As you say, colliders don't test GR.
Related to Randomness of radioactive decay
1. What is radioactive decay?
Radioactive decay is the process by which an unstable atom spontaneously releases energy and particles in order to become more stable. This process is random and cannot be predicted.
2. How is randomness involved in radioactive decay?
The randomness of radioactive decay is a fundamental aspect of this process. It is impossible to predict which atoms will decay and when, as it is a completely random event.
3. Can the randomness of radioactive decay be influenced or controlled?
No, the randomness of radioactive decay cannot be influenced or controlled. It is a natural process that occurs at the atomic level and is not affected by external factors.
4. Why is it important to study the randomness of radioactive decay?
Studying the randomness of radioactive decay is important for understanding the behavior of atoms and the natural world. It also has practical applications in fields such as nuclear energy and medicine.
5. Is radioactive decay truly random?
Yes, radioactive decay is truly random. While the probability of decay can be calculated for a large group of atoms, it is impossible to predict the decay of individual atoms. This is due to the inherent randomness of quantum mechanics at the atomic level.
  • Quantum Physics
  • Quantum Physics
  • Chemistry
  • Quantum Interpretations and Foundations
