Range of t in rational expression
In summary, the range of real values of $t$ for which the given equation is true is $\displaystyle t\in \left[-\frac{\pi}{2}\;,\frac{\pi}{2}\right]\;.$
juantheron
247
Evaluation of range of real values of $t$ for which $\displaystyle 2\sin t = \frac{1-2x+5x^2}{3x^2-2x-1}\;,$
Where $\displaystyle t\in \left[-\frac{\pi}{2}\;,\frac{\pi}{2}\right]$
Mathematics news on Phys.org
We have,
$\displaystyle \implies 3x^2-2x-1 = 2x\sin t - (1-2x+5x^2)\cos t\;,$
Comparing the coefficient of $x^2$ on both sides, we get
$\displaystyle 5\cos t = 3\Rightarrow \cos t = \frac{3}{5} \Rightarrow t = \cos^{-1}\left(\frac{3}{5}\right)\;,$
which lies in the given range, i.e. $\displaystyle t\in \left[-\frac{\pi}{2}\;,\frac{\pi}{2}\right]\;.$
Hence, the range of real values of $t$ for which the given equation is true is
$\displaystyle t\in \left[-\frac{\pi}{2}\;,\cos^{-1}\left(\frac{3}{5}\right)\right]\cup \left[\cos^{-1}\left(\frac{3}{5}\right)\;,\frac{\pi}{2}\right]\;.$
FAQ: Range of t in rational expression
What is the range of t in a rational expression?
The range of t in a rational expression is the set of all possible values that t can take on while still satisfying the given expression. In other words, it is the set of all real numbers that make the expression defined and meaningful.
How do you find the range of t in a rational expression?
To find the range of t in a rational expression, you can start by simplifying the expression and identifying any restrictions on the variable t. Then, you can determine the values of t that would make the expression undefined, such as division by zero. Once you have identified these restrictions, you can find the remaining range of t by plugging in different values for t and observing the resulting outputs.
Can the range of t in a rational expression be a negative number?
Yes, the range of t in a rational expression can include negative numbers. This is because rational expressions can have terms with negative coefficients or involve operations such as subtraction or division, which can result in negative outputs.
What happens if the range of t in a rational expression is undefined?
If the range of t in a rational expression is undefined, it means that there are no possible values of t that would make the expression defined and meaningful. This could happen if there are restrictions on t, such as division by zero, that cannot be resolved.
Can the range of t in a rational expression include fractions or decimals?
Yes, the range of t in a rational expression can include fractions or decimals. This is because rational expressions involve operations with fractions and can result in decimal outputs. It is important to simplify the expression and identify any restrictions on t to determine the full range of t.
10K
10K
10K
