Range of Values For Inequalities
In summary, the range of values in inequalities refers to the set of all possible values that satisfy the given inequality. It is determined by solving the inequality using algebraic methods and can be represented graphically on a number line or coordinate plane. The range of values can be infinite if there is no upper or lower limit, and finding it is significant in determining solutions and understanding limitations in various real-life applications.
kc1895
Here is a basic inequality question for which I cannot understand the answer:
If \(\displaystyle -1<a-b<10 ,and -3\le b\le1\) then what inequality represents the range of values of a2?
I plug-in -3 and 1 for b for boundaries and get -4<a<11.
Since the boundary is for a2, the range would be 16<a2<121.
But why would this be incorrect?
Thanks for your help!
Mathematics news on Phys.org
Given that:
\(\displaystyle -4<a<11\)
this implies:
\(\displaystyle 0\le|a|<11\)
Now, using:
\(\displaystyle |x|\equiv\sqrt{x^2}\)
we may write:
\(\displaystyle 0\le\sqrt{a^2}<11\)
And so squaring through the compound inequality, we obtain:
\(\displaystyle 0\le a^2<121\)
FAQ: Range of Values For Inequalities
What is the definition of "range of values" in inequalities?
The range of values in inequalities refers to the set of all possible values that satisfy the given inequality. It includes all numbers within a certain interval that make the inequality statement true.
How is the range of values determined for an inequality?
The range of values is determined by solving the inequality using algebraic methods such as addition, subtraction, multiplication, or division. The resulting solution will be a set of numbers that satisfy the inequality and make it true.
Can the range of values for an inequality be infinite?
Yes, the range of values for an inequality can be infinite if the inequality has no upper or lower limit. For example, in the inequality x > 5, the range of values would be all real numbers greater than 5, which is an infinite set.
How can the range of values for an inequality be represented graphically?
The range of values for an inequality can be represented on a number line or a coordinate plane. For example, the inequality x < 3 can be represented on a number line with an open circle at 3 and an arrow extending to the left, representing all numbers less than 3.
What is the significance of finding the range of values for an inequality?
Finding the range of values for an inequality can help determine the possible solutions or outcomes of a problem. It can also help identify the boundaries or limitations of a certain situation or scenario. In addition, it is an important concept in mathematics and is used in various real-life applications such as economics, engineering, and statistics.
