Range of values of force for string to remain in tension
In summary, the two strings in the picture must have a force that cancels each other out so that the tension in the picture remains the same. This was attempted by finding moments about point C such that the tensions in BC and AC could be canceled out. However, it was not possible to factorise the terms or cancel out the tension in BC.
Ljungberg92
The question is to find the range of values of force p such that the two strings in the picture remain in tension
None.
I tried to solve using moments about point C such that i can cancel out the tension in BC but it doesn't seem to work as the terms do not cancel each other out neither can i factorise out the terms.
Moments ? This is a force problem
Basically the 2 forces have to result in a force that has a vector with an angle of 0' to 50' relative to C.
How can you do that?
i don't quite seem to get you. which 2 forces are you talking about? you mean p and the 960N?
In statics you want the sum of the forces to net to 0.
This means in both x and y.
So you have the string exerting a force upward along both sides and the vertical components of those forces must add to 960N. The horizontal components must balance.
Since they give you the angles for each then you can write 2 equations for the two tensions necessary to satisfy the picture.
2 equations. 2 unknown tensions. 1 of them is the answer to your problem.
ok i got it my ans is p<-1804 or p>1920 is it possible? thanks
Seems awfully high.
Isn't in the x direction
T1*Cos30 = T2*Cos50
and in the y ...
T1*sin30 + T2*Sin50 = 960 ?
Solving for T1 shouldn't you get a number that's not all that different from the weight?
One question though.
Can the angle of P vary in any way? Are the strings really at AB and AC? Is this why you are asking for a range? Your drawing is unclear on this point. If it is, my comments are not exactly correct. I thought it was a string pointing at P.
AB and BC are 2 strings that are connected at the point where the 960N acts and force P is not a string but rather just a force applied at the angle of 30degrees. But from your equation, it seems that you totally ignored the tension in BC, shouldn't it be also included into the x direction?
I did indeed ignore it because I didn't understand from your drawing that BC was a string at all. It looked to me like a horizontal reference. I thought that P was the second string of interest.
Is the angle of P then fixed at 30°? Or can the force P vary in angle with the horizontal in any way?
yes it is fixed at 30 degrees. By the way i just solved for another more realistic ans for 672N<p<1920N
That looks more like it then. Because basically you solve both situations, i.e. the situation where one string has 0 tension, but not slack, and then the other.
My equations solved the first condition, where BC was 0.
I will trust that you similarly solved for when AB was 0.
thanks pion i have solved it using your way and the answers tally with my results earlier on, thanks alot.
FAQ: Range of values of force for string to remain in tension
What is the range of values of force for a string to remain in tension?
The range of values of force for a string to remain in tension depends on several factors, such as the material of the string, its diameter, and the length of the string. Generally, the force needed to keep a string in tension increases as the length and diameter of the string increases, and as the material becomes stiffer.
How is tension in a string measured?
Tension in a string is typically measured in units of force, such as newtons or pounds. It can be measured using a tension meter or by hanging weights from the string and measuring the force needed to lift them off the ground.
What happens if the force on a string exceeds its tension limit?
If the force on a string exceeds its tension limit, the string will break or stretch beyond its elastic limit, causing it to lose its ability to maintain tension. This can result in the string snapping or becoming loose, depending on the amount of force applied.
How can I determine the tension limit of a string?
The tension limit of a string can be determined by conducting a tension test, where the string is subjected to increasing amounts of force until it reaches its breaking point. The force at which the string breaks is its tension limit.
What are some common uses for strings under tension?
Strings under tension have a variety of uses, such as in musical instruments, suspension bridges, and weightlifting equipment. They are also used in sports equipment, such as tennis rackets and bowstrings, and in everyday items like shoelaces and sewing thread.
