Rapidly changing Hamiltonian and an observable
In summary: The statement is that after the experiment is started and the new hamiltonian is in place the state of the system is then a linear combination of the basis-vectors of H1.
titanandwire
Consider an experiment on a system that can be described using two basis functions. We begin in the ground state of a Hamiltonian H0 at a time t1, then rapidly change the hamiltonian to H1 at the time t1. At a later time tD>t1 you preform a measurement of an observable D.
[tex] H_0 =
\left(
\begin{array}{cc}
0 & -4\\
-4 & 6
\end{array}
\right),
\hspace{0.1in}
H_1 =
\left(
\begin{array}{cc}
1 & 0\\
0 & 3
\end{array}
\right),
\hspace{0.1in}
D =
\left(
\begin{array}{cc}
0 & 1\\
1 & 2
\end{array}
\right)
[/tex]
a ) What are the possible outcomes for the measurement of D? What is the state of the system after each measurement?
b ) If you preform many, many measurements what will be the average observed vaule of D as a function of t1 and tD (this is an exam task from 2004 from a MIT open course on quantum mechanics)
The eigenvalue equation
[tex]
det(A - \lambda I ) = 0
[/tex]
Fouriers trick, for a state ψ represented in a particular orthogonal basis fnthe coefficients can be found by:
[tex]
c_n =\langle f_n | \psi \rangle
[/tex]
By fouriers trick the probability of getting a particular eigenvalue of an operator Q, qn, associated by the orthonormalized eigenfunction fn
Expectation value of an observable Q is given by
[tex]
\langle Q \rangle = \sum _n q_n |c_n|^2
[/tex]
a)[/B]
Changing the hamiltonian rapidly results in an diabatic process which is characterized by the statement that the state doesn't change. Such that for t1 the system is in the ground state of H0, but expressed in the basis of H1. For the later time tD one can assume that the system has transitioned according to a tacked-on exponential time dependant term.
The eigenvalues of D is, from the eigenvalue equation. Which also are the possible measurements of D
[tex]
\lambda_{1, D} = -0.4 \\
\lambda_{2, D} = 2.4
[/tex]
The original hamiltonian has the normalized eigenvectors
[tex]
H_0 \frac{1}{\sqrt{5}} \left( \begin{array}{c} -2 \\ -1 \end{array}\right) = -2 \frac{1}{\sqrt{5}} \left( \begin{array}{c} -2 \\ -1 \end{array}\right) \\
H_0 \frac{1}{\sqrt{5}} \left( \begin{array}{c} -1 \\ 2 \end{array} \right)= 8 \frac{1}{\sqrt{5}} \left(\begin{array}{c} -1 \\ 2 \end{array}\right)
[/tex]
Such that the state with eigenvalue -2 is the groundstate of H0.
The new hamiltonian, H1 , then has eigenvectors that are the cartesian basis-vectors for ℝ2 (which we see quite trivially). With eigenvalues 1 and 3. At the time t1 before the experiment is started the system is then in the ground-state of H0. After the experiment is started and the new hamiltonian is in place the state of the system is then a linear combination of the basis-vectors of H1 and tacking on an exponential time dependence
[tex]
\frac{1}{\sqrt{5}} \left( \begin{array}{c} -2 \\ -1 \end{array} \right) = \frac{1}{\sqrt{5}} (-2e_1\cdot e^{-i(t- t_1)} - e_2 \cdot e^{-i3(t- t_1)})
[/tex]
Where e1 and e2 are the ordinairy cartesian basis vectors. At the time tD the system has gone to:
[tex]
|t_d \rangle= \frac{1}{\sqrt{5}} (-2e_1\cdot e^{-i(t_D- t_1)} - e_2 \cdot e^{-i3(t_D- t_1)})
[/tex]
b)
The expectation value of D at the time of measurement tD is given in the normal manner as
[tex]
\langle D \rangle =\langle t_d| D |t_d \rangle
[/tex]
Doing the matrix multiplication in the normal manner gives
[tex]
\langle D \rangle = \frac{2}{5}(e^{-6i(t_D - t_1)} + 2e^{-4i(t_D - t_1)})
[/tex]
EDIT1 : I realized I for some reason picked the excited state of H0. Corrected this!
EDIT2: Changed the statement "For the later time tD one can assume that the system has transitioned to the ground state of the changed hamiltonian H1." to "After the experiment is started and the new hamiltonian is in place the state of the system is then a linear combination of the basis-vectors of H1 and tacking on an exponential time dependence"
Sounds a little off to me. In the beginning specified by the time marker ##t_1## the system's Hamiltonian is ##H_0## then at time ##t_1##, which is the same instant as the first Hamiltonian, the system is changed to ##H_1##. Are you sure it was not ##t_0## when the system was still in ##H_0##?
What is the initial state? In your answer you assume that it starts from the ground state of ##H_0## but I think such information should be given in the question.
It's unnecessary, there is no reason why the system de-excite to the ground level (we are not considering atoms where the upper level has a finite life time due to the interaction with vacuum photon).
It's unnecessary, there is no reason why the system de-excite to the ground level (we are not considering atom where an upper level has a finite life time due to interaction with vacuum photon).
The initial state is the ground state of ##H_0##. It's formulated such that it's supposed to be a near instantaneous change from ##H_0## to ##H_1##, to reflect that it's a diabatic process I reckon they've chosen to use the same time parameter. It confused me a good bit too.
Yeah I that was an artifact of some earlier reasoning, edited it out just before you answered to reflect the new reasoning.
For a) you are also asked the final state corresponding to the possible outcomes of the measurement of ##D##. It doesn't look like you have the answer to this part already.
For b), your step is correct, I just don't have the time to check your calculation. But I believe it's a trivial matrix multiplication problem that you yourself can spot any error if you do recheck.
I probably misunderstood then. I figured the question " What is the state of the system after each measurement" meant measurement in the sense of "a change in the system" i.e. to find the ground state of ##H_0##, then its representation in the basis of ##H_1## and finally tacking on the time dependence to the same state and setting ##t = t_D##. If it instead means the state associated with the possible measurements of ##D## that would be to find the eigenvalues of the matrix representation of ##D##, as far as I've understood.
The exam also has another question "At tD, you measure D, then the energy and then D again in rapid (i.e. essentially instantaneous) succession. What is the probability that the two measurements of D yield the same result?" After measuring D, you collapse the wavefunction into an eigenstate of D, ##D_n## with a particular measurement value, ##d_n##. The probability of each of these states are given by their coefficients
[tex]
P(D_n) = \frac{|d_n|^2}{\sum_n |d_n|^2}
[/tex]
This statement should hold for non-normalized states too. So the probability of getting a measurement twice is then the probability of the first, squared (to account for it being measured twice). Plus the probability of the second, also squared. Have I understood that correctly or am I way off?
titanandwire said:
If it instead means the state associated with the possible measurements of DD that would be to find the eigenvalues of the matrix representation of DD, as far as I've understood.
The possible states after measuring ##D## are its eigenvectors.
If by first and second as underlined in the quoted statement above are the first and second eigenvectors of ##H_1##, then yes I believe that should be the correct way.
Related to Rapidly changing Hamiltonian and an observable
1. What is a rapidly changing Hamiltonian?
A rapidly changing Hamiltonian is a mathematical representation of a physical system that is undergoing significant changes over a short period of time. It is used in quantum mechanics to describe the time evolution of a system.
2. How does a rapidly changing Hamiltonian affect the dynamics of a system?
A rapidly changing Hamiltonian can cause the dynamics of a system to become highly non-linear and unpredictable. This is because the system is undergoing rapid changes, making it difficult to accurately predict its behavior.
3. What is an observable in relation to a rapidly changing Hamiltonian?
An observable is a physical quantity that can be measured or observed in a system. In the context of a rapidly changing Hamiltonian, an observable is a quantity that can be predicted and measured at different points in time as the system evolves.
4. How is the Heisenberg uncertainty principle related to a rapidly changing Hamiltonian?
The Heisenberg uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute certainty. In the case of a rapidly changing Hamiltonian, this uncertainty principle becomes even more relevant as the system is constantly changing and becoming more unpredictable.
5. Can a rapidly changing Hamiltonian affect the stability of a system?
Yes, a rapidly changing Hamiltonian can greatly affect the stability of a system. As the Hamiltonian changes rapidly, the system may become more chaotic and unstable, making it difficult to predict and control its behavior.
