Rate at which the distance from a plane to a station is increasing.
In summary, the conversation discusses finding the rate at which the distance from a plane to a radar station is increasing when the plane is 2 miles away from the station. This is done by using the altitude and horizontal distance to form a right triangle and taking the derivative with respect to time. The conversation also touches on the use of customary and metric units in the US.
dinogal
So a plane flying horizontally at an altitude of 1 mi and a speed of 50 mi/h passes directly over a radar station. Find the rate at which the distance from the plane to the station is increasing when it is 2 mi away from the station.
(Music)
Let \(\displaystyle A\) be the altitude of the plane, which is 1 mi. Let \(\displaystyle H\) be the horizontal distance from the plane to the station, which changes based on time. Let \(\displaystyle D\) be the distance to the radar station.
The altitude and horizontal distance form a right triangle with the distance as the hypotenuse, so
\(\displaystyle D = \sqrt{A^2 + H^2}\)
To find how fast the distance changes with time, take the derivative with respect to time \(\displaystyle t\). Also, note that \(\displaystyle A\) never changes, so \(\displaystyle dA/dt = 0\)
\(\displaystyle \frac{dD}{dt} = \frac{1}{2}(A^2 + H^2)^{-\frac{1}{2}}(2H\frac{dH}{dt})\)
The question asks for the value of \(\displaystyle \frac{dD}{dt}\) when \(\displaystyle H\) is 2 miles, and \(\displaystyle dH/dt\) is 50 mi / hr.
(Music)
What do you mean by when it is 2 mi away from the station, is this the horizontal distance, or the slant range. As it is written the usual assumption would be slant range but I see that at least one other poster has assumed it is the plan range (horizontal distance).
CB
PS: To the USA in general , and partially to the UK for that matter, smarten up and stop using customary/imperial units, you only confuse yourselves when having to convert between customary units and metric.
I wish we would. I have hoped for this since the early 70s when a partial effort was made here, but I was a child at that time and I remember the prevailing attitude among the adults was that the metric system was somehow un-American (as if the system we do use is). Alas, the meager effort was abandoned, and we have been steadfastly stubborn ever since. Maybe another effort will be made here within the next century.
The education system could make a start by not setting homework problems in customary units.
CB
The US is slowly moving in that direction. For instance, the size of engines is moving towards metric. They are measured in Litres instead of cubic inches many times now. My father is an elevator mechanic, and nearly all elevators parts are in metric now. He actually had to go out and buy a new set of tools because of this change. Believe me, we are moving that way... but half the battle is that we have had our units for a very long time now. Most of America would be confused as to units.
A very good example is speed, I know that 80kph is about 50mph... I believe... Most Americans would have no idea...
I see nothing wrong with a country using their traditional measurements
FAQ: Rate at which the distance from a plane to a station is increasing.
What is the meaning of "rate at which the distance from a plane to a station is increasing"?
The rate at which the distance from a plane to a station is increasing refers to how quickly the distance between the plane and the station is getting larger over time. It is a measure of the change in distance between the two objects.
How is the rate at which the distance is increasing calculated?
The rate at which the distance from a plane to a station is increasing can be calculated by dividing the change in distance by the change in time. This is known as the average rate of change. Alternatively, it can be calculated using calculus by finding the derivative of the distance function with respect to time.
What factors can affect the rate at which the distance from a plane to a station is increasing?
The rate at which the distance from a plane to a station is increasing can be affected by various factors such as the speed of the plane, the distance between the plane and the station, and any other external forces acting on the objects.
How does the rate at which the distance is increasing relate to the speed of the plane?
The rate at which the distance from a plane to a station is increasing is directly proportional to the speed of the plane. This means that as the speed of the plane increases, the rate at which the distance is increasing also increases, and vice versa.
Can the rate at which the distance from a plane to a station be negative?
Yes, the rate at which the distance from a plane to a station can be negative. This would indicate that the distance between the two objects is decreasing over time. It is important to keep track of the sign of the rate, as it indicates whether the distance is increasing or decreasing.
