Rate of Change in Area of Triangle with Fixed Sides
In summary, the conversation discusses finding the rate at which the area of a triangle is increasing when the angle between two sides of fixed length is changing at a given rate. Using the formula for finding the area of a triangle, differentiating it, and plugging in the given values, the rate is found to be approximately $\frac{0.3m^2}{s}$.
karush
MHB
3,269
$29.$ Two sides of a triangle are $4 \, m$ and $5 \, m$ in length and the angle between them is increasing at a rate of $\frac{0.06 \, rad}{s}$
Find the rate at which the area of the triangle is increasing when the angle between the sides of fixed length. $\frac{\pi}{3}$
$\displaystyle
A=\frac{1}{2}(4)(5\sin{\theta})\\
\text{differentiate}\\
\displaystyle
\frac{dA}{ds}
=10\cos{\theta}\frac{d\theta}{ds}\\
\displaystyle\theta=\frac{\pi}{3}
\text{ and }
\displaystyle
\frac{d\theta}{ds}
=\frac{0.6 rad}{s}\\
\text{so far??} $
$\displaystyle
\displaystyle
\frac{dA}{ds}
\text{ and }
\displaystyle
\frac{d\theta}{ds}
\text{so far??} $
Are you told that the angle is pi/3?
Yes $\theta$ is $\frac{\pi}{3}$
the book answer is $\frac{0.3m^2}{s}$
So $\d{A}{s}
=10\left(\frac{1}{2}\right)\frac{0.6\pi}{s}
=9.4248 \\$
Then $\d{A}{s}\approx\frac{0.3m^2}{s}$
kinda ??
FAQ: Rate of Change in Area of Triangle with Fixed Sides
What is the formula for calculating the rate of change in area of a triangle with fixed sides?
The formula for calculating the rate of change in area of a triangle with fixed sides is (1/2) * base * change in height.
How do you find the rate of change in area when the base and height are changing?
To find the rate of change in area when the base and height are changing, you can use the formula (1/2) * (base + change in base) * (height + change in height) - (1/2) * base * height.
Can the rate of change in area be negative?
Yes, the rate of change in area can be negative. This indicates that the area of the triangle is decreasing.
What does a positive rate of change in area mean?
A positive rate of change in area means that the area of the triangle is increasing.
Is there a relationship between the rate of change in area and the slope of the triangle's base?
Yes, the rate of change in area is equal to the slope of the triangle's base multiplied by half of the triangle's height.
