- 15,829
- 8,986
To clarify my previous post, you need a general expression that is valid when the charge and current vary with time.
I = d Q / d t?kuruman said:To clarify my previous post, you need a general expression that is valid when the charge and current vary with time.
Right.moenste said:I = d Q / d t?
d Q / d t = (1 / R) (d Φ / d t)kuruman said:Correct. So put together to get a differential equation using the alternate expression for I, Post #41.
d Q = (d t / R) d Φkuruman said:Multiply both sides of the first equation by dt and integrate. What do you get?
Time term should not show up in the equation. That's why you were asked to multiply both the sides by dt. That will eliminate the time variable.moenste said:d Q = (d t / R) d Φ
Q = t Φ / R?
kuruman said:No. You have an extra dt on the right that doesn't belong.
Q = Φ / R = B A N / R?cnh1995 said:Time term should not show up in the equation. That's why you were asked to multiply both the sides by dt. That will eliminate the time variable.
B = μ0 n I = 4 π * 10-7 * 1000 * 4 = 5 * 10-3 T.kuruman said:Bingo. Calculate the right side with numbers and you are done.
Right.moenste said:Q = Φ / R = B A N / R?
That should be 1.34*10-4..moenste said:B = μ0 n I = 4 π * 10-7 * 1000 * 4 = 5 * 10-3 T.
Q = 2000 * (8 * 10-4) * (5 * 10-3) / 60 = 1.33 * 10-4 C
θ = a Q = 2 * 1.34 * 10-4 = 2.68 * 10-4.cnh1995 said:That should be 1.34*10-4..
Use sensitivity of the galvanometer to find the number of divisions.
Well, 1.34*10-4 is the actual charge passed through the galvanometer. You have sensitivity as 2 divisions/ microcoulomb. How would you calculate the no of divisions from this?moenste said:θ = a Q = 2 * 1.34 * 10-4 = 2.68 * 10-4.
θ = a Q = deflections of the galvanometer.cnh1995 said:Well, 1.34*10-4 is the actual charge passed through the galvanometer. You have sensitivity as 2 divisions/ microcoulomb. How would you calculate the no of divisions from this?
Right.moenste said:θ = a Q = deflections of the galvanometer.
Update
1.34 * 10-4 C → 1.34 * 10-4 / 10-6 = 134 μC.
134 * 2 = 268. I think this should be right.
