Rate of change of current with time, galvanometer deflection
In summary, a solenoid with an inductance of 2.0 H is connected in series with a resistor and a 2.0 V DC supply. The final current is 4.0 A and the initial rate of change of current with time is 1.0 A s^-1. When the current is 2.0 A, the rate of change of current with time is 0.5 A s^-1. An EMF greater than 2.0 V is produced when the current is switched off. In a separate scenario, a long air-cored solenoid with 1000 turns of wire per metre and a cross-sectional area of 8.0 cm^2 has a secondary coil
  • #36
kuruman said:
We have already agreed that Φ = B A N. You can't have Φ = B I A N at the same time.
Answer me this: The secondary is not connected to a battery or power supply. Why should there be a current in it?
Because they are close together and have mutual inductance?
  • #37
Yes they have mutual inductance, but the mutual inductance by itself does not cause a current to flow in the secondary. What causes the induced current flow?
Please read and understand this, then try answering the question again.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html
Likes moenste and cnh1995
  • #38
We find V first: V = I R = 4 * 60 = 240 V. Then we find d Φ / d t: E = - N (d Φ / d t) → d Φ / d t = 240 / 2000 = 0.12 Wb s-1.
Now we need to somehow find the magnetic field from flux, though we don't know time.
And then we use θ = a N B A / R to find the deflection θ.
  • #39
You can't say this. The 4.0 A is the current in the primary and the 60 Ω is the total resistance in the secondary. You don't know how much current flows in the secondary but you can write an algebraic expression for it in terms of the induced emf. What is that expression? (No numbers please, just symbols.)
Likes moenste
  • #40
Maybe something like I = E / R = - (1 / R) * (d / d t) * (N Φ), where E = - (d / d t) * (N Φ)?
  • #41
That's what you want, ## I = \frac{1}{R} \frac{d\Phi}{dt}##. The negative sign can be dropped because we looking for magnitudes. Remember, we are looking for the total charge that flows in the secondary. We just found an expression for the current in the secondary. How is the current related to the charge in the secondary?
  • #42
But we don't know I and B in it Why do we need it?
  • #43
I think you do know B (and Φ) in the secondary. The secondary has the same area of 8cm2 as you said in an earlier post.
Likes moenste
  • #44
As @cnh1995 remarked, you know B and therefore Φ. Maybe, just maybe, you don't need I, so just answer my question "How is the current related to the charge in the secondary?"
  • #45
But no B is given in the problem. And all my calculations here are wrong:
moenste said:
(b) As I understand we need to find θ: θ = a N A B / R, where a is the division per microcoulomb, N = turns, A = cross-sectional area, B = magnetic field and R = resistance. If this formula is correct, I'm not sure how to find B. Maybe something like: B = μ0 n I = 4 π * 10-7 * 1000 * 4 = 5 * 10-3 T. Then plug into the formula: θ = 2 * 2000 * (8 * 10-4) * (5 * 10-3) / 60 = 2.68 * 10-4. It has the 2.68 in it as in the answer 268 divisions. But still I'm not sure whether I'm in the right direction.
Q charge = M I / R, where M is standard mutual inductance.
  • #46
You can calculate B. You have the sufficient data to calculate B and Φ.
Likes moenste
  • #47
No. What is the general relationship between charge and current?
Likes moenste
  • #48
If you don't remember look it up.
Likes moenste
  • #49
Q = I t.
  • #50
No, look it up.
Likes moenste
  • #51
To clarify my previous post, you need a general expression that is valid when the charge and current vary with time.
Likes moenste
  • #52
I = d Q / d t?
  • #53
Correct. So put together to get a differential equation using the alternate expression for I, Post #41.
Likes moenste
  • #54
moenste said:
I = d Q / d t?
Right.
Likes moenste
  • #55
d Q / d t = (1 / R) (d Φ / d t)
d (B A N / R) / d t = (1 / R) (d B A N / d t)
d (μ0 N I A N / R) / d t = (1 / R) (d μ0 N I A N / d t).
  • #56
Multiply both sides of the first equation by dt and integrate. What do you get?
Likes moenste
  • #57
d Q = (d t / R) d Φ
Q = t Φ / R?
  • #58
No. You have an extra dt on the right that doesn't belong.
Likes moenste
  • #59
moenste said:
d Q = (d t / R) d Φ
Q = t Φ / R?
Time term should not show up in the equation. That's why you were asked to multiply both the sides by dt. That will eliminate the time variable.
Likes moenste
  • #60
Q = Φ / R = B A N / R?
  • #61
Bingo. Calculate the right side with numbers and you are done.
Likes moenste
  • #62
Q = 2000 * (8 * 10-4) * (5 * 10-3) / 60 = 1.33 * 10-4 C
  • #63
Right.
Likes moenste
  • #64
That should be 1.34*10-4..
Use sensitivity of the galvanometer to find the number of divisions.
Likes moenste
  • #65
θ = a Q = 2 * 1.34 * 10-4 = 2.68 * 10-4.
  • #66
Well, 1.34*10-4 is the actual charge passed through the galvanometer. You have sensitivity as 2 divisions/ microcoulomb. How would you calculate the no of divisions from this?
Likes moenste
  • #67
θ = a Q = deflections of the galvanometer.
Update
1.34 * 10-4 C → 1.34 * 10-4 / 10-6 = 134 μC.
134 * 2 = 268. I think this should be right.
  • #68
Update
Right.
Likes moenste
