MHB Rate of Change of Plane's Distance from Radar Station - Gina's Question
The discussion focuses on calculating the rate at which the distance from a plane to a radar station is increasing when the plane is 5 miles away. The plane flies at an altitude of 1 mile and a speed of 470 miles per hour. Using the Pythagorean theorem and implicit differentiation, the formula for the rate of change of distance is derived. Substituting the known values into the equation yields a result of approximately 461 miles per hour. This calculation provides the desired rate of change for the scenario presented.
MarkFL
MHB
Here is the question:
related rates; Find the rate at which the distance from the plane to the station is increasing when it is..?
A plane flying horizontally at an altitude of 1 mi and a speed of 470 mi/h passes directly over a radar station. Find the rate at which the distance from the plane to the station is increasing when it is 5 mi away from the station. (Round your answer to the nearest whole number.)
__ mi/h
thanks will vote best answer!
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Gina,
First, let's draw a diagram:
The plane is at $P$, the radar station is at $R$, $h$ is the altitude of the plane (which is constant since its flight is said to be horizontal) and $x$ is the distance from the radar station to the point on the ground (or at the same level as the radar station) directly below the plane. $s$ is the distance from the plane the the radar station.
Using the Pythagorean theorem, we may state:
(1) $$x^2+h^2=s^2$$
Implicitly differentiating (1) with respect to time $t$, we find:
$$2x\frac{dx}{dt}=2s\frac{ds}{dt}$$
We are interested in solving for $$\frac{ds}{dt}$$ since we are asked to find the rate at which the distance from the plane to the station is increasing when it is 5 mi away from the station. So, we find:
$$\frac{ds}{dt}=\frac{x}{s}\frac{dx}{dt}$$
Now, we do not know $x$ but we know $h$ and $s$, and so solving (1) for $x$ (and taking the positive root since it represents a distance), we find:
$$x=\sqrt{s^2-h^2}$$
And so we have:
$$\frac{ds}{dt}=\frac{\sqrt{s^2-h^2}}{s}\frac{dx}{dt}$$
Now, the speed $v$ of the plane represents the time rate of change of $x$, hence:
$$v=\frac{dx}{dt}$$
and so we may write:
$$\frac{ds}{dt}=\frac{v\sqrt{s^2-h^2}}{s}$$
Now, we may plug in the given data:
$$v=470\frac{\text{mi}}{\text{hr}},\,s=5\text{ mi},\,h=1\text{ mi}$$
and we then find:
$$\frac{ds}{dt}=\frac{470\sqrt{5^2-1^2}}{5} \frac{\text{mi}}{\text{hr}}=188\sqrt{6}\frac{\text{mi}}{\text{hr}}\approx460.504071643238 \text{ mph}$$
And so we have found that the rate at which the distance from the plane to the station is increasing when it is 5 mi away from the station is about 461 mph.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
