i_m_mimi
- 17
[10marks] A water tank has the shape of a vertex-down right circular cone. The depth
of the tank is 9 meters, and the top of the tank has radius 6 meters. Water
flows into the tank from a hose at a constant rate of 14 cubic metres per
hour, and leaks out of a hole at the bottom of the tank at a rate of kh cubic
metres per hour when the depth of water in the tank is h metres. Here k is a
constant. When the water is 3 metres deep in the tank, its surface is rising at
the instantaneous rate of 2 metres per hour. Find the value of the constant k.
Answer: k = 2pi
V = 1/3 pi r^2 h
made so many attempts on paper, including
r/h = 6/9
V = 1/3pi (6h/9)^2h = 4/27pi h^3
rate of change in volume = rate which water is poured in minus rate water leaks out
V' = 14pi m^3/hour - X
X = rate water leaks out
V' 12/27 (h^2)(h')
h' = 3
V' = 2/3 pi r r' h + h' pi r^2
V' = 2/3 pi (2)(2)h + (3) pi (2)^2
V' = 8/3 pi h + 4pi
X = 14pi - 8/3 pi h + 4pi
X = 10pi - 8/3 pi h
I'm not sure how to change the equation into rate water leaks out = kh form,
i keep on getting solutions where h is either not present or h^2
I think I've made mistakes somewhere in there and it is a complicated question worth 10 marks and with 20 minutes allocated to it on an exam.
thank you
