MHB Rate Problem: How many minutes does it take 14 people to paint 14 walls?
  • Thread starter Thread starter bp05528
    Paint Rate
It takes 28 minutes for 7 people to paint 7 walls, indicating that each person paints one wall in that time. Consequently, if 14 people are painting 14 walls at the same rate, they will also take 28 minutes to complete the task. The formula for such problems confirms that doubling both the number of workers and the workload does not change the time required. The logic holds that the rate of work remains constant regardless of the number of participants. Therefore, the answer is that it takes 28 minutes for 14 people to paint 14 walls.
bp05528
It takes 28 minutes for 7 people to paint 7 walls.
Mathematics news on Phys.org
If the walls are the same size and each individual paints at an equal rate (1 person paints 1 wall in 28 minutes), then it takes the same amount of time ... 28 minutes.
Hi bp05528.
There is a very useful formula for problems of this kind:
If $X_1$ “producers” can make $Y_1$ “products” in time $T_1$ and $X_2$ “producers” can make $Y_2$ “products” in time $T_2$ at the same rate, then
$$\boxed{\frac{X_1T_1}{Y_1}\ =\ \frac{X_2T_2}{Y_2}}.$$
Example: If $5$ hens can lay $5$ eggs in $5$ days …
  • how long will it take $10$ hens to lay $10$ eggs?
  • how many hens can lay $10$ eggs in $10$ days?
  • how many eggs will $10$ hens lay in $10$ days?
Answers: (a) $5$ days, (b) $5$ hens, (c) $20$ eggs. You can either work the answers out by simple logic, or use the formula above, where the “producers” are hens and the “products” are eggs.
In this case of your problem:
the “producers” are the wall painters and “products” are painted walls. Substituting $X_1=7$, $Y_1=7$, $T_1=28$, $X_2=14$, $Y_2=14$ into the formula gives
$$\frac{7\cdot28}7\ =\ \frac{14\cdot T_2}{14}$$
$\implies\ T_2=28$ minutes. (In other words, it takes the same time for twice the number of people to do twice the amount of work – which makes sense, doesn’t it?)
Here is the proof of the formula above.
$X_1$ producers make $Y_1$ products in time $T_1$
$\implies$ $1$ producer makes $\dfrac{Y_1}{X_1}$ products in time $T_1$
$\implies$ $X_2$ producers make $\dfrac{X_2Y_1}{X_1}$ products in time $T_1$
$\implies$ $X_2$ producers make $\dfrac{X_2Y_1}{X_1T_1}$ products in time $1$
$\implies$ $X_2$ producers make $\dfrac{X_2Y_1T_2}{X_1T_1}$ products in time $T_2$.
That is to say,
$$Y_2\ =\ \frac{X_2Y_1T_2}{X_1T_1}$$
which can be rearranged to the formula above.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
