Rate will this student burn calories
In summary, the student's plan to sit naked in a 12.5° C room and let his body radiate calories away in order to burn calories faster is not effective. According to the calculations, he would only be burning calories at a rate of 502.35 J/s, which is not enough to significantly contribute to weight loss.
lalahelp
75
rate will this student "burn" calories
A student wants to lose some weight. He knows that rigorous aerobic activity uses about 700 kcal/h (2900 kJ/h) and that it takes about 2000 kcal per day (8400 kJ) just to support necessary biological functions, including keeping the body warm. He decides to burn calories faster simply by sitting naked in a 12.5° C room and letting his body radiate calories away. His body has a surface area of about 1.7 m2 and his skin temperature is 35° C. Assuming an emissivity of 1.0, at what rate will this student "burn" calories?
dQ/dt=h.A.dT
1*1.7*295.5
=502.35 J/s
Why is my answer wrong?
Is T not 288.5K ?
marcoskids said:
Is T not 288.5K ?
Sorry 285.5K
Yes your right but even with that I still get the wrong answer
Your answer is incorrect because you have not taken into account the conversion from Joules to calories. The correct equation to use for this problem is Q = m.c.(Tf-Ti), where Q is the amount of energy in calories, m is the mass of the student, c is the specific heat capacity of the body, Tf is the final temperature (12.5°C in this case), and Ti is the initial temperature (35°C in this case).
Once you have calculated the amount of energy (in calories) that the student's body will lose per second, you can divide by 3600 (the number of seconds in an hour) to determine the rate at which he will burn calories. This will give you a more accurate answer.
Additionally, it is important to note that this method of weight loss is not safe or effective. The body needs a certain amount of energy (calories) to function properly, and drastically reducing calorie intake or trying to burn them off through extreme methods can have negative consequences on overall health. It is always best to consult with a healthcare professional before making any significant changes to your diet or exercise routine.
Related to Rate will this student burn calories
What is the best way to calculate calorie burn rate for a student?
The best way to calculate calorie burn rate for a student is by using a formula that takes into account their weight, activity level, and duration of exercise. This can be found through various online calculators or by consulting with a fitness professional.
How many calories can a student expect to burn in a given amount of time?
The number of calories a student can expect to burn in a given amount of time depends on their unique factors such as weight and activity level. On average, a person can burn anywhere from 100-300 calories in a 30-minute exercise session.
What types of exercises are best for burning calories?
The best types of exercises for burning calories are those that involve high intensity and use multiple muscle groups, such as running, cycling, and interval training. However, any type of physical activity can help burn calories.
Is there a specific heart rate range that is most effective for burning calories?
The most effective heart rate range for burning calories varies for each individual and is based on factors such as age, fitness level, and overall health. Generally, a higher heart rate (around 70-85% of maximum heart rate) will result in a higher calorie burn.
How can a student increase their calorie burn rate?
A student can increase their calorie burn rate by incorporating high intensity exercises, increasing the duration of their workouts, and by consistently challenging and pushing themselves during exercise. Additionally, maintaining a healthy and balanced diet can also help increase calorie burn rate.
