Darkmisc
- 213
- 28
If you divided the circumference of an infinitely large circle by its diameter, would the result be pi?
andrewkirk said:There is no such thing as an infinitely large circle, even in theory.
I have thought about a solution of this kind, but couldn't imagine a sensible way to define diameter and circumference. Also projective spaces seem to be of little help. I'm quite sure that the passage to the limit as phrased in the OP would only lead to something like ##\frac{\infty}{\infty} = \pi##. But interesting to know about generalized circles. (Where the h... do you know all these exceptional and exotic stuff from? I never even came close to it.)micromass said:Perhaps by going to the Riemann sphere model...
fresh_42 said:I have thought about a solution of this kind, but couldn't imagine a sensible way to define diameter and circumference. Also projective spaces seem to be of little help. I'm quite sure that the passage to the limit as phrased in the OP would only lead to something like ##\frac{\infty}{\infty} = \pi##. But interesting to know about generalized circles. (Where the h... do you know all these exceptional and exotic stuff from? I never even came close to it.)
A thought of mine has been another generalization: What happens in higher dimensions?
If we consider ##n-##spheres, then the volume (of the surface) becomes ##V(S_r^n) = c(n) \cdot r^{n}## for some function ##c(n)##.
Then ## c(n) = 2 \pi^{\frac{n+1}{2}} \Gamma(\frac{n+1}{2})## and all the magic about the definition of ##\pi## is camouflaged by this function ##c##.
In this case we would have driven research on ##c## and ##\pi## would have been simply ##\frac{1}{2} c(1)##.
Of course the magic will return by the vast number of occurrences of ##\frac{1}{2} c(1)## and we might would have named it ##\pi##. However, the question in the OP would look rather exotic from this point of view: What happens to ##\frac{V(S_r^1)}{c(1)}## if ##r## is infinitely large?
The ##2-##dimensional world is a rather special one and so is ##\pi##. A metric at infinity appears edgy to me.
The value of the ratio of circumference to diameter for infinitely large circles is equal to π (pi).
The ratio of circumference to diameter for infinitely large circles is the same for all circles, while regular circles have varying ratios depending on their size.
The ratio of circumference to diameter for infinitely large circles is important because it is a fundamental constant in mathematics and is used in many calculations involving circles and spheres.
Yes, the ratio of circumference to diameter for infinitely large circles can be calculated using the formula π (pi) = C/d, where C is the circumference and d is the diameter.
Yes, the ratio of circumference to diameter for infinitely large circles is used in many real-world applications such as calculating the volume of spheres, determining the distance between two points on a sphere, and in navigation and map-making.
