MHB Ratio of the Area of Similar Polygons
The perimeter of the smaller polygon is calculated to be 39 cm, confirming the initial finding. The ratio of the lengths of the corresponding sides of the similar polygons is 3 to 7. Consequently, the ratio of their areas is determined to be 9 to 49, as area scales with the square of the linear dimensions. This relationship highlights the consistent proportionality between similar shapes. Understanding these ratios is essential for solving problems involving similar polygons.
Hobbes1
Two corresponding sides of two similar polygons have lengths 3 and 7. the perimeter of the larger polygon is 91 cm. What is the perimeter of the smaller polygon? What is the ratio of their areas?
I believe I have found the perimeter of the smaller polygon (39), but I can't figure out the areas.
Thanks.
Mathematics news on Phys.org
I will use the subscript $S$ for the smaller polygon, and $L$ for the larger...
For similar planar shapes, the ratio of any corresponding linear measures will be the same. And so the perimeter $P_S$ of the smaller polygon will be:
$$P_S=\frac{3}{7}P_L=\frac{3}{7}\cdot91=\frac{3\cdot7\cdot13}{7}=3\cdot13=39$$
So, you did find the correct value there. (Yes)
Because the area of a planar shape varies as the square of any of its linear measures, then we will find:
$$\frac{A_S}{A_L}=\left(\frac{3}{7}\right)^2=\frac{9}{49}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
