Ratio of the rate of decay of R to that of S after 2 hours
In summary, the ratio of the rate of decay of R to that of S after 2 hours is a measure of the relative decay rates of two substances. It is important because it indicates the stability or activity of the substances. The ratio is calculated by dividing the rate of decay of R by the rate of decay of S. It can change over time due to various factors and can be used in scientific research, such as radiocarbon dating and understanding the properties of substances.
moenste
711
At a certain time, two radioactive sources R and S contain the same number of radioactive nuclei. The half-life is 2 hours for R and 1 hour for S. Calculate:
(a) the ratio of the rate of decay of R to that of S at this time.
(b) the ratio of the rate of decay of R to that of S after 2 hours.
(c) the proportion of the radioactive nuclei in S which have decayed in 2 hours.
Answers: (a) 1 : 2, (b) 1 : 1, (c) 75 %.
2. The attempt at a solution
I get how to approach (c). At t = 0 hours we have 100 % of S, in 1 hour we'll have 50 % of it and in one more hour we'll have half of that -- 25 %. So in two hours 75 % of S decayed.
Though I don't quite understand what is required in (a) and (b). In both cases they decay 1 : 2, since S decays faster. Maybe I miss something.
Note that the rate of decay is proportional to the remaining number of nuclei.
Likes moenste
(a) t = 0. dN / dt = ?
NR = 100 % = NS.
T1/2 R = 2 hours
T1/2 S = 1 hour.
dN / dt = - λ N
dN / dt = - (ln 2 / T1/2) * N
R [dN / dt] = 9.6 * 10-5
S [dN / dt] = 1.9 * 10-4
R for S = 0.5 or 1 : 2.
(b) t = 2 hours
NR = 50 %, NS = 25 %.
T1/2 R = 2 hours
T1/2 S = 1 hour.
dN / dt = - λ N
R [dN / dt] = 9.6 * 10-5 * 0.5 = 4.8 * 10-5
S [dN / dt] = 1.9 * 10-4 * 0.25 = 4.75 * 10-5
R for S = 1 : 1.
Like this, right?
Probably (I haven't checked carefully) but that's far more complicated than you need, as you can simply use ratios between the two cases rather than working them out. As you've already used above, exponential decay rates vary as the inverse of the half life, so if the half lives are in the ratio m:n then the decay rates for the same number of nuclei are in the ratio n:m. Then after 2 hours the amount of R is 1/2 of the original and the amount of S is 1/4 of the original, so there's now twice as much R left as S.
Likes moenste
Related to Ratio of the rate of decay of R to that of S after 2 hours
1. What is the ratio of the rate of decay of R to that of S after 2 hours?
The ratio of the rate of decay of R to that of S after 2 hours is a measure of how much faster one substance decays compared to another. It is calculated by dividing the rate of decay of R by the rate of decay of S at the 2-hour mark.
2. Why is the ratio of the rate of decay of R to that of S after 2 hours important?
This ratio is important because it can provide information about the relative stability or activity of different substances. A higher ratio indicates a faster decay rate, while a lower ratio suggests a slower decay rate.
3. How is the ratio of the rate of decay of R to that of S after 2 hours calculated?
The ratio is calculated by dividing the rate of decay of R by the rate of decay of S. This can be done by measuring the amount of each substance present at the 2-hour mark and using their respective decay equations to determine their individual rates of decay.
4. Can the ratio of the rate of decay of R to that of S after 2 hours change over time?
Yes, the ratio can change over time as the rates of decay for R and S may not remain constant. Factors such as temperature, pressure, and the presence of other substances can affect the rates of decay and therefore alter the ratio.
5. How can the ratio of the rate of decay of R to that of S after 2 hours be used in scientific research?
The ratio can be used in various scientific studies, such as in the field of radiocarbon dating, to determine the age of a sample. It can also provide insights into the nature of a substance and its potential uses, such as in the development of new medicines or in environmental studies.
