MHB Ratio word problem: What fraction of the original counters remain in the bag
A word problem involves a bag of red and blue counters, where counters are removed until a fraction of each color is depleted. Specifically, 1/4 of the red counters and 3/5 of the blue counters are taken out. The calculations show that if n counters are removed, the ratio of blue to red counters is 5 to 12. After determining the original quantities, it is concluded that 11/17 of the original counters remain in the bag. This solution highlights the importance of understanding ratios and fractions in problem-solving.
Jessica15
I have a word equation i cannot figure out! anyone have any ideas?
There is a large bag of red and blue counters. One red and one blue counter are removed from the bag. This process is repeated until 1/4 of the red counter and 3/5 of the blue counters have been removed. What fraction of the original counters remain in the bag?
Im stumped!
I've written that:
Red - n = 3/4 Red
blue - n = 2/5 blue
n is the number of counters removed as it the same number removed from both.
therefore n = 1/4red and n = 3/5 blue. therefore 1/4 red = 3/5 blue. if you cross multiply that you get that 5 red = 12 blue... I don't know how that helps!
Mathematics news on Phys.org
n = (3/5)B
----------- $\implies$ 1 = (12B)/(5R) $\implies$ B/R = 5/12 ... 5 blue, 12 red, 17 total
n = (1/4)Rif n = 3, 3 blue counters are removed = 3/5 ofthe original 5 ... 3 red counters are removed = 1/4 of the original 12
2 blue and 9 red counters remain ... 11/17 of the original counters remain
Hint:
r = 24, b = 10, n = 6
r: 24 - 6 = 18 : 3/4 left
b: 10 - 6 = 04 : 2/5 left
B/r = 5/12 = 10/24 = 15/36 = ...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
