clotfelterjk
- 2
9/se^{2}-4 = 4-5s/s-2
It's not clear from your question exactly what it is that you are trying to do. Do you want to solve for s?clotfelterjk said:9/se^{2}-4 = 4-5s/s-2
A rational equation is an equation that contains at least one fraction with a variable in the denominator. It is also known as a fractional equation.
To solve a rational equation, you need to first find the common denominator and then cross-multiply to eliminate the fractions. After that, you can solve the resulting equation as you would a regular algebraic equation.
The most common mistake when solving rational equations is forgetting to exclude any extraneous solutions. This can happen when you multiply both sides of the equation by a variable that is also a solution to the denominator, resulting in a false solution.
Yes, a rational equation can have more than one solution. In fact, it is common for rational equations to have multiple solutions. However, it is important to check for extraneous solutions and simplify the final answer to its lowest form.
You can check your solution by plugging it back into the original equation and seeing if it satisfies the equation. If it does, then it is a valid solution. You can also check your solution by graphing the original equation and seeing if the point of intersection matches your solution.
