MHB Rational exponents expressed as fractions
The discussion focuses on how to work with rational exponents expressed as fractions in mathematical expressions. Participants clarify the notation and guide on multiplying constants and adding exponents when the bases are the same. For example, in the expression (4a^(3/2))(2a^(1/2)), the constants multiply to 8, and the exponents combine to give a final result of 8a^2. Another example discussed involves (3x^(5/6))(8x^(2/3)), where the constants multiply to 24, and the exponents combine to yield 24x^(3/2). The conversation emphasizes the importance of understanding the basics of adding and multiplying fractions to solve these problems effectively.
CSmith1
can someone help me
(4a 3/2)(2a1\2)
(3x5/6)(8x2/3)
(27a6)-2/3
the fractions are powers
Mathematics news on Phys.org
CSmith said:
can someone help me (4a 3/2)(2a1\2)
(3x5/6)(8x2/3)
(27a6)-2/3
Hi CSmith. We'll be glad to help but you need to try to be more precise with your notation. For example, what does (4a 3/2)(2a1\2) mean?
Is it [math]\left(4a \cdot \frac{3}{2} \right) \left(2a \cdot \frac{1}{2} \right)[/math]?
they are thge exponents the fractions.written on top of 4a etc...
CSmith said:
can someone help me
(4a 3/2)(2a1\2)
(3x5/6)(8x2/3)
(27a6)-2/3
If the fractions are powers then let's look at the first one.
[math]4a^{\frac{3}{2}} \cdot 2a^{\frac{1}{2}}[/math]
What you need to do is multiply the constants together and then combine the powers somehow. Here's the trick. If you have [math]a^{x} \cdot a^{y}=a^{x+y}[/math]. So when you multiply things in this situation you can add the powers if they have the same base.
What do you get when you try that?
Until you learn how to use Latex on our site I suggest using the ^ sign to indicate exponents. :)
would it6 ,^3+1=6^4.
No, the "a" variable disappeared in your answer. It will still be there! :)
The answer is [math]8a^{2}[/math] because of the constants, 4*2=8, and when you add the powers you get [math]\frac{1}{2}+\frac{3}{2}=\frac{4}{2}=2[/math]. So once again you multiply the constants and add the powers when they have the same base. In this case the base was "a".
Does that make sense?
EDIT: Just to make sure the steps are easy to follow, [math]4a^{\frac{3}{2}} \cdot 2a^{\frac{1}{2}} = 8a^{\frac{1}{2}+\frac{3}{2}}=8a^{\frac{4}{2}}=8a^2[/math]
ok thanks
if i have (3x5 ^5/6) (8x^2/3)would it be 11x how would i work out the 5/6 and the 2/3 in this
CSmith said:
ok thanks
I can't figure out your notation. Does (3x5 ^5/6) mean [math]3x^{\frac{5}{6}}[/math]? Please put exponents in parentheses like this: x^(5/6).
I'm assuming that (8x^2/3) means [math]8x^{\frac{2}{3}}[/math]
Yes
Ok, so you have [math]3x^{\frac{5}{6}} \cdot 8x^{\frac{2}{3}}[/math]. This is exactly the same situation as the one I've done for you. You first look at the constants (3 and 8) and multiply them together. Then you look at the variable, "x", and the powers. Since they both have the same base then you just add the powers together like I did in the problem I solved for you. What do you get when you try that?
ok i got -24x and the base is 6 and 3 right
Why -24? Yes the constants multiply together to get 8*3=24.
If you have an exponent in the form of [math]x^{a}[/math], x is the base and a is the exponent. When you multiply two things with the same base, x in this case, you add the exponents together. For example [math]x^2 \cdot x^5 = x^7[/math] because 2+5=7.
Your two exponents are [math]\frac{5}{6}[/math] and [math]\frac{2}{3}[/math]. You must combine them together by adding.
yeah i accidently placed the negative.
24x7/9
CSmith said:
24x7/9
Closer. [math]\frac{5}{6}+\frac{2}{3} \ne \frac{7}{9}[/math].
[math]\frac{2}{3}=\frac{4}{6}[/math] and now you can add them because they have the same bottom number, or denominator.
[math]\frac{5}{6}+\frac{2}{3}=\frac{5}{6}+\frac{4}{6}= \frac{9}{6}=\frac{3}{2}[/math]
So the final answer is [math]24x^{\frac{3}{2}}[/math]
Has your teacher gone over how to solve these problems in your class? It looks like you haven't been given sufficient material to know how to do these so it's understandable that you are having trouble. I recommend brushing up on adding and multiplying fractions as well. They can be tough! :)
well my math teacher only gives out sums to try .Different sums that has several different formats.i feel as if he should focus on one type of situation when dealing with rationals and then focus on the next so that it would be more organized and more easier to catch on.he gives different sums with completely diferent concepts. I am just trying to do the sums in my textbook for practice to understand the different ways myself.how did u get the 2/3 and
Here is a video from Khan Academy on adding and subtracting fractions. I recommend watching it to review this material.
The basics of the kinds of problems from your original post are:
1) Multiply constants
2) If two exponents have the same base, then add exponents together
3) Simplify if possible and you have your answer
Ok thank you sir. i appreciate it
Sure :) If you have other questions please post them. I just think that for this particular kind of question you would do better to watch some videos or read through your textbook and then in a bit coming back to ask any more questions you have on this type of problem.
khan university really cleared up a lot of things
