Rational Number equations help
  • MHB
  • Thread starter Paige1
  • Tags
    Rational
In summary, the product of a rational number and its inverse is equal to 1, with the exception of zero, which does not have an inverse. The multiplicative inverse of a rational number can be found by taking the reciprocal of the numerator.
Paige1
I have a question in math I need help with please:
Show that the product of a rational number and it's inverse is equal to 1, with one exception. what is the exception? can anyone help please?
Mathematics news on Phys.org
zero is the exception as it does not have inverse
Thank you!
- - - Updated - - -
however, what is the product of the rational number and it's inverse?
We could choose to let the rational number be:
\(\displaystyle \frac{m}{n}\) where \(\displaystyle m,n\in\mathbb{Z}\land m\ne0\) (This just means $m$ and $n$ are integers, with $m$ not equal to zero.)
So, what would the multiplicative inverse, or reciprocal, of $m$ be?
I can confirm that rational number equations are indeed very helpful in solving mathematical problems. In regards to your question, I would be happy to provide an explanation.
To show that the product of a rational number and its inverse is equal to 1, we can use the general form of a rational number: a/b, where a and b are integers and b ≠ 0. The inverse of this rational number would be b/a.
Now, when we multiply a rational number and its inverse, we get (a/b) * (b/a) = ab/ba. Since a and b are integers, we can simplify this to 1, making the product equal to 1.
However, there is one exception to this rule. The exception occurs when the rational number is 0. In this case, the inverse would be undefined, as we cannot divide by 0. Therefore, the product of 0 and its inverse would not be equal to 1.
I hope this explanation helps. If you need further assistance, please do not hesitate to ask for help. Remember, as scientists, we are always here to support and assist in any way we can.
FAQ: Rational Number equations help
What are rational numbers?
Rational numbers are numbers that can be expressed as a ratio of two integers. This includes both positive and negative fractions, as well as whole numbers and integers.
How do you solve an equation with rational numbers?
To solve an equation with rational numbers, you can use the same rules and methods as you would with other numbers. For example, you can combine like terms, use the distributive property, and isolate the variable on one side of the equation.
What is the difference between a rational number equation and an irrational number equation?
A rational number equation contains only rational numbers, while an irrational number equation includes irrational numbers, such as pi or square roots of non-perfect squares.
Can you solve a rational number equation with decimals?
Yes, you can solve a rational number equation with decimals by converting the decimals to fractions. To do this, you can either use the long division method or simply move the decimal point to the numerator and add a denominator of 1.
Are there any special rules for solving rational number equations?
There are no special rules for solving rational number equations, but it is important to remember to check for extraneous solutions, which are solutions that do not satisfy the original equation.
