MHB Rationalising Surds: Get the Answers You Need - Daniel
  • Thread starter Thread starter danielw
To rationalize surds, the discussion focuses on simplifying the expression for √63, which is correctly simplified to 3√7. The method for finding x involves determining that x is 7, as it fits within the bounds of the perfect squares 7² and 8². For y, the discussion clarifies that it must be negative, leading to the conclusion that y is -8 after applying the appropriate inequalities. The distinction between integers and natural numbers is also emphasized, highlighting the need for careful consideration of the problem's requirements. This approach effectively addresses the initial question and provides clarity on the rationalization process.
danielw
Hi All
This is my question.
I don't know how to begin working on it.
I already tried simplifying the first part to: $$ \sqrt{63} = \sqrt{7 \cdot 3^3}=\sqrt{7}\sqrt{3^2}=3\sqrt{7}$$
But this doesn't get me closer to answering the first part of the question, and I think the same technique will apply to the second part. I would be grateful for some guidance!
Thanks.
Daniel
Mathematics news on Phys.org
To find $x$, consider:
$$x^2\le63<(x+1)^2$$
So, think of the perfect squares that will fit the bill here:
$$7^2\le63<8^2$$
Thus, $x=7$...can you now find $y$?
$$7^2\le63<8^2$$
So since $$y^2=-(51)$$, $$y$$ is between 7 ($$7^2=49$$) and 8 ($$8^2=64$$), $$y=7$$?
The question for finding $y$ has an error in it...we are looking for an integer rather than a natural number. Natural numbers are denoted by $\mathbb{N}$ whereas integers are denoted by $\mathbb{Z}$.
We observe that $y$ must be a negative number (do you see why?), and so we can write:
$$(y+1)^2\le51<y^2$$
Since all 3 values are negative, we change the direction of the inequality when squaring.
And if we write:
$$7^2\le51<8^2$$
We may then write:
$$y^2=8^2$$
And we take the negative root here, to obtain:
$$y=-8$$
Does this make sense?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
