Rationalization of bond angle/ bond pair repulsions.
In summary: This combination of factors results in the smallest observed bond angle in CH2Br2. In summary, the bond angles for H2S and H2O differ due to the difference in electronegativity and the presence of lone pairs. The total sum of bond angles in CH3X is 450 degrees due to the maximum bond-pair<->bond-pair repulsion in the C-H bonds. The smallest bond angle in CH2Br2 is observed in the H-C-Br bond due to the combination of Br-Br repulsion and lone pair repulsion.
admXXII
I need help rationalizing the following:
a) Bond angle for H2S is only 92o whereas bond angle for H2O is 104.5o.
b) If bond-pair<-> bond-pair repulsion is maximum for the C-H bonds in CH3X, ∑ all bond angles is 450o for CH3X
c) For CH2Br2, the H-C-Br will be the smallest bond angle observed.
main considerations:
a) magnitude of central atom non-bonding pairs<->single bonding pairs repulsion w/ bonding-pair <-> bonding pair.
b) I got nothing
c) Br- Br repulsion? Magnitude of Br
see main considerations
I realize this is a lot. I appreciate any help/ guidance from someone with a firm grasp on this stuff.
Thanks in advance.
a) The difference in bond angles between H2S and H2O can be explained by the difference in electronegativity between sulfur and oxygen. Oxygen is more electronegative than sulfur, meaning it has a stronger pull on electrons. This results in a greater bond-pair<->bond-pair repulsion in H2O, causing the bond angle to be larger compared to H2S. Additionally, H2O has two lone pairs of electrons on the central oxygen atom, which also contribute to the smaller bond angle by pushing the bonding pairs closer together.
b) The total sum of bond angles in CH3X is 360 degrees. However, the bond angles are not all equal due to the different electronegativities of the atoms involved. The C-H bonds will have the smallest bond angles due to the difference in electronegativity between carbon and hydrogen. The bond-pair<->bond-pair repulsion between these bonds will be maximum, hence the smaller bond angles. The total sum of bond angles being greater than 360 degrees can be explained by the presence of lone pairs on the central carbon atom, which also contribute to the bond angle.
c) In CH2Br2, the H-C-Br bond angle will be the smallest observed due to the presence of two larger bromine atoms on either side of the central carbon atom. This results in a greater magnitude of Br-Br repulsion, pushing the H-C-Br bond angle closer together. Additionally, the lone pairs on the central carbon atom also contribute to the smaller bond angle by pushing the bonding pairs closer together.
Related to Rationalization of bond angle/ bond pair repulsions.
1. What is the rationalization of bond angle and bond pair repulsions?
The rationalization of bond angle and bond pair repulsions is a theory that explains the relationship between the angle formed by two covalent bonds and the repulsion between the electron pairs involved in those bonds. It states that the electron pairs in a molecule will arrange themselves in a way that minimizes repulsion, resulting in a specific bond angle.
2. How does the rationalization of bond angle and bond pair repulsions affect molecular geometry?
The rationalization of bond angle and bond pair repulsions plays a crucial role in determining the molecular geometry of a molecule. The bond angle between two atoms is determined by the number of bonding and non-bonding electron pairs around the central atom, which is directly related to the repulsion between those pairs.
3. What factors influence bond angle and bond pair repulsions?
The main factors that influence bond angle and bond pair repulsions are the number of bonding and non-bonding electron pairs around the central atom, the electronegativity of the atoms involved, and the steric hindrance caused by bulky groups attached to the central atom.
4. How do lone pairs affect bond angle and bond pair repulsions?
Lone pairs of electrons have a stronger repulsive effect compared to bonding electron pairs. This is because lone pairs are closer to the central atom and thus experience less shielding from other electrons. As a result, lone pairs tend to compress bond angles, resulting in a smaller bond angle compared to a molecule with only bonding electron pairs.
5. What is the relationship between bond angle and bond strength?
The bond angle in a molecule is directly related to the strength of the bond. A smaller bond angle indicates a greater repulsion between the bonding electron pairs, which requires more energy to break the bond. Therefore, molecules with smaller bond angles tend to have stronger bonds compared to those with larger bond angles.
9K
